Re: ALTERNATOR WIRING 101..................... [Re: Thumperdart] #2434120
01/13/18 09:48 PM
01/13/18 09:48 PM
CA
crackedback Offline
crackedback  Offline
CA
This is going to get back to where you are pulling power and wire sizing serving it up.
I'm guessing you have a cutoff switch. If you have a wire headed forward to power the cabin, what is sizing? Maybe take a secondary wire and piggyback it forward to see if voltage increases to a higher level when load from accessories increases. If the voltage is higher, you need to upsize or piggyback another wire forward would be my guess.
Re: ALTERNATOR WIRING 101..................... [Re: crackedback] #2434254
01/14/18 03:09 AM
01/14/18 03:09 AM
State of confusion
Thumperdart Offline OP
State of confusion
Yes on the cut off switch and NAPA made me a big dog years ago but not sure on the exact size but it was WAY lighter than the welding cable and I only lose about a .10 of a volt from the alt. to the batteries in the trunk...........The HHR fan and the Moroso water pump are needy for sure in the amp dept........... thumbs
