freeze plug fitment issue #2424356
12/27/17 01:29 PM
12/27/17 01:29 PM
RapidRobert Offline OP
SB 360. I have some Dorman 1&5/8" & they practically fall into the block openings & the freeze plug OD is a bit wavy. I did grab one dorman 41/64 which is a hair larger just to see if it would fit & if so then I would get more of that size IF they are available in a thick (wide) version (like the 1&5/8's are that do not fit). is there a better brand that fits tighter? I could go brass if they tend to be tighter. thank you for your time.
Re: freeze plug fitment issue [Re: RapidRobert] #2424364
12/27/17 01:56 PM
12/27/17 01:56 PM
md
mopars4ever Offline
mopars4ever  Offline
md
How deep are the cups? Some are more shallow then others. The deeper ones worked well for me. Honestly I don`t like Dorman stuff but I don`t remember the brand I used.
Re: freeze plug fitment issue [Re: mopars4ever] #2424399
12/27/17 02:59 PM
12/27/17 02:59 PM
the deep 1&5/8 ones are 9/16 "tall" & the 1&11/64 one that fits better but is only a weak 3/8" tall.
Re: freeze plug fitment issue [Re: RapidRobert] #2424420
12/27/17 03:38 PM
12/27/17 03:38 PM
md
mopars4ever Offline
mopars4ever  Offline
md
IIRC they should be 1 5/8. I think I might have used Sealed Power brand but not 100%
Re: freeze plug fitment issue [Re: mopars4ever] #2424494
12/27/17 05:11 PM
12/27/17 05:11 PM
yes the block hole(s) & the Dorman plugs are 1&5/8 but it is way too loose. I'm gonna try a brass one I have & if no go then see if I can find the Sealed Power 1&5/8's you mentioned.
Re: freeze plug fitment issue [Re: RapidRobert] #2424572
12/27/17 07:48 PM
12/27/17 07:48 PM
My brass one fits alot tighter (& probably a good idea to use brass anyhow especially on the (2) rear plugs). it says 1635C with no brand. I Googled it as a sealed power # but nothing come up, anyone know what brand it might be?
Re: freeze plug fitment issue [Re: RapidRobert] #2424578
12/27/17 07:59 PM
12/27/17 07:59 PM
md
mopars4ever Offline
mopars4ever  Offline
md
EPC 1635c pioneer brand. Says its for small block chevy but may fit others.
Re: freeze plug fitment issue [Re: mopars4ever] #2424592
12/27/17 08:21 PM
12/27/17 08:21 PM
that'll work, thank you for hanging with me on this.
Re: freeze plug fitment issue [Re: RapidRobert] #2432051
01/10/18 03:09 AM
01/10/18 03:09 AM
left to right: EPC 41 steel. unknown brand brass. pioneer 1635C brass. The chinese steel dorman I first tried practically fell into the bores.
Re: freeze plug fitment issue [Re: RapidRobert] #2432200
01/10/18 02:38 PM
01/10/18 02:38 PM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
Dorman shows only steel plugs in slightly over and under size.
I've always checked their catalog, picked up some locally (usually have to order) and pick the one I like best.
here is their data for 360
362660.1 - 1-41/64 In., Height 0.360
555-033 - 1-45/64 In. SC, Height 0.270
555-068 - 1-41/64 In., Height 0.360
555-068.1 - 1-41/64 In., Height 0.360
555-072 - 1-21/64 In. SC, Height 0.300
sc is shallow cup that you may have, try the .36?
Re: freeze plug fitment issue [Re: srt] #2432205
01/10/18 02:45 PM
01/10/18 02:45 PM
Good info & I may very have had one of their slightly undersize ones (I didn't retrieve a # or take a pic like I should of) but it did about fall into the bore. Now that you mention it I did try a 1&41/64 & it was a tight fit just setting it up to the bore & I was worried that I might crack something if I drove it in & it was steel & haveing always used steel & everyone touting brass I decided to go with brass (at least on the 2 rear hidden ones). I certainly was not expecting the amt of difficulty I had on this simple issue.
Re: freeze plug fitment issue [Re: RapidRobert] #2433817
01/13/18 11:33 AM
01/13/18 11:33 AM
California, United States and ...
Dibbons Offline
Dibbons  Offline
The Dorman's I just received (made in China) are obviously now chamferred so they seem loose and go in half-way by hand. It seems to be a manufacturing modification to help us get them started in the hole easier. I don't believe they are defective or too large.
Re: freeze plug fitment issue [Re: Dibbons] #2433846
01/13/18 12:36 PM
01/13/18 12:36 PM
moparx  Offline
has anyone tried loctite "green" as a sealant for freeze plugs ?
Re: freeze plug fitment issue [Re: RapidRobert] #2434106
01/13/18 09:14 PM
01/13/18 09:14 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Interesting, I replaced the freeze plugs in a '77 318 and a '68 383 last summer and simply asked for the kit for those motors at Orielys and thought nothing of it.
They fit perfect.
Still no idea what brand they are. shruggy
I really should start taking notes. whistling
I've never needed sealant with freeze plugs.
I have mechanical Aptitude.
I can screw up anything.
Re: freeze plug fitment issue [Re: RapidRobert] #2434402
01/14/18 01:55 PM
01/14/18 01:55 PM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
I typically use just a smear of non hardening permatex on the plug, mainly as a "lube". plugs are so tight they will wipe anything from the walls as they are inserted. I like the thought that should there be any scraping or imperfections in the bore walls there is some form of sealant available to plug and not leak. Done it that way for years and never had one leak.
Re: freeze plug fitment issue [Re: srt] #2437786
01/20/18 01:41 AM
01/20/18 01:41 AM
got (20) Pioneer EPC41's coming from Oreillys for $11.22 including shipping which ain't bad. that'll be enough for 2 blocks & an extra or two. these are the ones on the left in the pic. all Done. thanks guys.
