Are 1976 D100 cabs VIN marked/stamped? Cab swap? #2423783
12/26/17 12:00 AM
12/26/17 12:00 AM
Texas
GoodysGotaCuda Offline OP
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I am looking to see what the appropriate way to restore my 1976 Warlock is.
We bought the truck from my Father-in-Law, it's really my Wife's truck, it has some sentimental value. The truck isn't in great shape, both cab corners are shot, the lower portion of the doors were poorly patched and it has a hacked aftermarket sunroof.
The easy solution would be to find a cleaner [one can dream of a rust-free] cab and just swap it. Are the truck cabs stamped/marked with a VIN like some certain areas of car chassis?
Obviously I am not looking for anything dishonest, I'll put a roof on it if I need to....but if swapping cabs is an "okay" thing to do, I'm interested! What's the verdict?
2020 RAM 1500
Re: Are 1976 D100 cabs VIN marked/stamped? Cab swap? [Re: GoodysGotaCuda] #2423793
12/26/17 12:30 AM
12/26/17 12:30 AM
Freeport IL USA
poorboy Online content
poorboy  Online Content
Freeport IL USA
That is pretty murky territory. The cab has the truck Vin number on it. According to the State of IL, the title goes with the frame, and everything beyond it are replacement parts, but they like to affix a "new" vin number on a replacement cab.
The correct answer is to check with your state DMV and ask them their procedure for swapping a damaged cab. Its been done a lot over the years. Gene
Re: Are 1976 D100 cabs VIN marked/stamped? Cab swap? [Re: GoodysGotaCuda] #2423816
12/26/17 01:52 AM
12/26/17 01:52 AM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
Goody, get hold of you local State Troopers (and maybe DMV) and ask them the legalities in Texas. Theirs is the only blessing that matters. Let us know what you find out...
Re: Are 1976 D100 cabs VIN marked/stamped? Cab swap? [Re: Fat_Mike] #2423867
12/26/17 12:22 PM
12/26/17 12:22 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
That's probably my best bet. I wasn't sure if this would be at a state-level, or higher. thumbs
2020 RAM 1500
Re: Are 1976 D100 cabs VIN marked/stamped? Cab swap? [Re: GoodysGotaCuda] #2424149
12/26/17 11:03 PM
12/26/17 11:03 PM
North East USA
BIGGERED Offline
Reasonable Title
BIGGERED  Offline
Reasonable Title
North East USA
Not sure there is any actual vin stamped in the cab of a 1976 truck.
Thought the vin plate is on the door and ECS offers the vin data sticker .
Re: Are 1976 D100 cabs VIN marked/stamped? Cab swap? [Re: GoodysGotaCuda] #2424232
12/27/17 01:51 AM
12/27/17 01:51 AM
Mid Michigan
Mr. Smurf Offline
Mr. Smurf  Offline
Mid Michigan
I would (have & will) just swap the cab and not worry about it.
There are thousands of re-cabbed trucks out there and more being done every day.
Ed
Re: Are 1976 D100 cabs VIN marked/stamped? Cab swap? [Re: GoodysGotaCuda] #2424328
12/27/17 12:26 PM
12/27/17 12:26 PM
Wisconsin USA
themoparmanjc Offline
Wisconsin USA
I wouldn’t worry about it. Take pictures for documentation. It’s not like you are trying to do anything unlawful. It’s much safer than trying to piece together a rusty cab. Just make sure your new cab had a title. Take it to dmv and explain everything and ask them which title they want you to use. Or just do it without asking. It’s not as big a deal as some of these guys rebodying rare muscle cars.
Don’t Buy From Famous Bob AKA Bob McCarty in Oklahoma. He is a Crook!
Re: Are 1976 D100 cabs VIN marked/stamped? Cab swap? [Re: GoodysGotaCuda] #2424359
12/27/17 01:41 PM
12/27/17 01:41 PM
Canada
demon Offline
demon  Offline
Canada
No. There is no VIN stamped on the cab on the 70's trucks.
Re: Are 1976 D100 cabs VIN marked/stamped? Cab swap? [Re: GoodysGotaCuda] #2424829
12/28/17 12:34 PM
12/28/17 12:34 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Thanks for the feedback all. I will run the traps locally and see what turns up. Regardless, I need to find a donor roof.
What year cabs directly interchange? Is a standard bed cab the same as a step side?
2020 RAM 1500
Re: Are 1976 D100 cabs VIN marked/stamped? Cab swap? [Re: GoodysGotaCuda] #2425211
12/29/17 01:55 AM
12/29/17 01:55 AM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
If I remember correctly, 72-80 cabs are the same....and no difference between step side and regular. I'm not sure if an AC cab would be different like cars are, as far as the firewall goes? shruggy
Re: Are 1976 D100 cabs VIN marked/stamped? Cab swap? [Re: GoodysGotaCuda] #2425369
12/29/17 02:44 PM
12/29/17 02:44 PM
Cruising!
Q
QuickDodge Offline
QuickDodge  Offline
Q
Cruising!
On some of the 1970's trucks there was a sticker on the door jamb with the VIN number. Of course the actual VIN number was on the door as previously noted. I have no idea what years / models had the sticker on the jamb. Over time, most of those stickers have probably faded and peeled off.
On the differences between cabs, some trucks had the fuel tank in the cab. The early 1970's models had a different dash than the later 70's trucks. I think there were a few very minor changes to the fire wall when the dash was changed...but I may not be remembering that correctly. Someone told me the 1972's had an different sized window. (rear window or windshield??) Some of the cabs had a removable cover to access the transmission.
On the legality of the swap, I'd take "Poorboy's" advice and check with your local government officials. There are other states which require a new VIN number for a cab swap. It may not be a big deal to get the new VIN number...but I'd check with the state first. Then you can make a more informed decision.
Re: Are 1976 D100 cabs VIN marked/stamped? Cab swap? [Re: GoodysGotaCuda] #2425397
12/29/17 03:59 PM
12/29/17 03:59 PM
Laveen, Arizona
GTSDart340 Offline
GTSDart340  Offline
Laveen, Arizona
72 to about 75.5 had a smaller rear window. I found out the hard way when I needed a window for my 75.
1949 International KB-2 "Mater" - 302/T5
1968 Dodge Dart GTS "The Drat" - 340/727
2006 Dodge Magnum R/T - Hemi
2016 Dodge Durango Limited - 3.6
Re: Are 1976 D100 cabs VIN marked/stamped? Cab swap? [Re: QuickDodge] #2425745
12/30/17 12:56 PM
12/30/17 12:56 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
'78 the tag was on the driver side door.
I was rather surprised to find this out.
I use a title that matches whatever cab I use, just in case.
As others have said I would not worry about it.
I have mechanical Aptitude.
I can screw up anything.
Re: Are 1976 D100 cabs VIN marked/stamped? Cab swap? [Re: bboogieart] #2426153
12/31/17 01:41 AM
12/31/17 01:41 AM
Mid Michigan
Mr. Smurf Offline
Mr. Smurf  Offline
Mid Michigan
Difference in cab floors also.
Small hump for 2wd autos & 3 on the tree, big hump for 4 speeds & 4x4's.
Ed
Re: Are 1976 D100 cabs VIN marked/stamped? Cab swap? [Re: GoodysGotaCuda] #2427557
01/02/18 02:05 AM
01/02/18 02:05 AM
Canada
demon Offline
demon  Offline
Canada
Lots of various changes in the cabs over the years. Best to get a cab of the same year as your truck. Yes they all will interchange though.
72-74 have an obvious rounded shape to the floor beside the seat when you open the door and look down. They also mounted the jack on that rounded hump on the passenger side.
72 cabs have a pipe welded to the cowl for the heater blower pipe, and use a spring clamp to hold a flex hose, and the 74 and newer cabs have a hole where a plastic moulded pipe fits in.
All rear window openings are the same. It is the glass and rubber that are different.
Several floor hump versions over the years. Small hump for 2wd automatics, medium removable hump for some 2wd manuals, large removable hump for 4wd and some 2wd manuals,
All firehall heater openings from 72-80 are the same size.
Re: Are 1976 D100 cabs VIN marked/stamped? Cab swap? [Re: GoodysGotaCuda] #2439705
01/23/18 08:09 PM
01/23/18 08:09 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
please post what you find out Goody. I have a truck that needs a new roof. a cab swap might be easier?? i'd like to know what considered legal by txdmv standards...
my truck has a little VIN sticker on in the doorjamb of the cab..but it also has VIN on the dash because it's a military truck.
