Re: Harbor Freight Engine Cherry Picker / Lifting an Engine
[Re: MuuMuu101]
#2423022
12/24/17 10:13 AM
12/24/17 10:13 AM
Posts: 20,625 in a cattle trailer down by th...
Guitar Jones
First, did you try it to see if it works? I've never had to add oil to any cylinder either.
[Re: MuuMuu101]
#2423023
12/24/17 10:15 AM
12/24/17 10:15 AM
Guitar Jones
I'm not sure the cherry picker I have has had that plug for the last 5 years. A wrap around the ram with electrical tape and it's good to go. I like the way you think. Duct tape!
[Re: MuuMuu101]
#2423086
12/24/17 02:13 PM
12/24/17 02:13 PM
rowin4
I never had to ad oil to my cherry picker but to bottle jacks. The rubber plugs are difficult to get in but I have used a small screw driver to work it in. I have also lost the rubber plug upon removal , bing and it was gone forever. The duct tap method was used and has been on for years.
[Re: MuuMuu101]
#2425266
12/29/17 10:21 AM
12/29/17 10:21 AM
Posts: 2,103 Byron, NY
W.I.N. Racing
Byron, NY
OMG...
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: Guitar Jones]
#2425362
12/29/17 02:36 PM
12/29/17 02:36 PM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
First, did you try it to see if it works? I've never had to add oil to any cylinder either. Yes I did! Because of that I ended up reading the instructions which states, "Hyrdaulic Oil Not Included."
[Re: mopars4ever]
#2425367
12/29/17 02:41 PM
12/29/17 02:41 PM
Posts: 20,151 PA.
pittsburghracer
Its really not that hard guys. A little lube and push it in.
[Re: mopars4ever]
#2425370
12/29/17 02:48 PM
12/29/17 02:48 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
Did the instructions say how to remove and install the rubber plug? LOL The instructions didn't even refer that the plug was the fill hole.
