Electrical question 70 challenger #2419618
12/16/17 09:56 PM
12/16/17 09:56 PM
VA
jh27-1970 Offline OP
VA
So when I start my car the gauges and all accessories take a while to work. The fuse block is two parts. two leads energizes the parts that I'm talking about. Its cold and seems that when it warms up it works. The delay is longer the colder it is. Has anyone had this happen to them? I'm thinking something is contracting with the cold and makes contact when warm? Thanks. Geoff
Re: Electrical question 70 challenger [Re: jh27-1970] #2419631
12/16/17 10:34 PM
12/16/17 10:34 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Might be the gauge regulator behind the panel.
Re: Electrical question 70 challenger [Re: jh27-1970] #2419669
12/17/17 12:16 AM
12/17/17 12:16 AM
VA
VA
Thanks, It is somewhere pre fuse block, when warm all works fine when cold nothing works for a few minutes then works. Gremlins...
Re: Electrical question 70 challenger [Re: jh27-1970] #2419801
12/17/17 12:36 PM
12/17/17 12:36 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
It is on the back of the panel, with the gauges.
Re: Electrical question 70 challenger [Re: 71birdJ68] #2419808
12/17/17 12:43 PM
12/17/17 12:43 PM
RapidRobert Offline
RapidRobert  Offline
Google or eBay to get a pic of it (if needed).
Re: Electrical question 70 challenger [Re: jh27-1970] #2419838
12/17/17 01:36 PM
12/17/17 01:36 PM
Supercuda Offline
Supercuda  Offline
gauge regulator will have zero effect on accessories.
Odds are whatever is feeding the regulator is also feeding the accessories and it's probably the ignition switch that is flaky.
Get the FSM and a meter to troubleshoot.
http://www.mymopar.com/index.php?pid=109
Don't be the exception.
Re: Electrical question 70 challenger [Re: jh27-1970] #2420686
12/18/17 11:41 PM
12/18/17 11:41 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
EZ to troubleshoot..
Get a schematic and volt/ohm meter.
Sounds like a high resistance/bad connection, a couple places to check are:
1. Ignition switch
2. Bulkhead connectors
3. (2) Flat-inline connectors that go in/out the steering column up to the ignition switch
4. Connections to amp guage
Just my $0.02.. wink
Re: Electrical question 70 challenger [Re: Sinitro] #2431344
01/08/18 11:21 PM
01/08/18 11:21 PM
VA
VA
thanks your 2c was worth a lot more!
