Is bumping an engine hard on the starter Drive?
#2416778
12/11/17 03:01 PM
12/11/17 03:01 PM
Posts: 7,471 Minnesota
Hemi_Joel
Minnesota
When lashing valves I usually turn the engine with a wrench. I have used a remote starter button to bump the engine over before, but I have been concerned that it's beating up the starter drive and ring gear. Possibly leading to a failure at the worst possible moment. What's your experience with this? Am I being overly paranoid?
Re: Is bumping an engine hard on the starter Drive?
[Re: Hemi_Joel]
#2416779
12/11/17 03:05 PM
12/11/17 03:05 PM
Posts: 4,457 Washington
madscientist
Washington
Way overly paranoid. If your starter can't take bumping to set valve lash that thing is junk.
[Re: Hemi_Joel]
#2416784
12/11/17 03:21 PM
12/11/17 03:21 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Its no different than just starting the engine that has a real good ignition where it wants to start real quick.. long crank times are harder on it than a short hit
[Re: Hemi_Joel]
#2416801
12/11/17 03:59 PM
12/11/17 03:59 PM
Hemi_Joel
Minnesota
Ok, bumpity bump it shall be.
[Re: Hemi_Joel]
#2416815
12/11/17 04:24 PM
12/11/17 04:24 PM
Posts: 15,976 Chilliwack B.C. Canada
RUNCHARGER
I always do it by hand. That way I hit the marks perfectly without going too far. I usually pull the plugs too, nice to have a look at them anyway.
Sheldon
[Re: Hemi_Joel]
#2416823
12/11/17 04:37 PM
12/11/17 04:37 PM
Thumperdart
State of confusion
When lashing valves I usually turn the engine with a wrench. I have used a remote starter button to bump the engine over before, but I have been concerned that it's beating up the starter drive and ring gear. Possibly leading to a failure at the worst possible moment. What's your experience with this? Am I being overly paranoid? I prefer the NON lazy wrench method cos starters are designed to start your car not set valves although many do.........Plus, the wrench is more accurate since you control it............
[Re: Stanton]
#2416849
12/11/17 05:30 PM
12/11/17 05:30 PM
MR_P_BODY
I use the starter to get most of the turn then do it with a ratchet to get it on the money.. no plugs in it
[Re: MR_P_BODY]
#2416906
12/11/17 06:49 PM
12/11/17 06:49 PM
Posts: 43,007 Bend,OR USA
I do it both ways depending on how hard it is to get the socket and breaker bar on the crankshaft bolt I wouldn't try using the starter with all the plugs out
[Re: Hemi_Joel]
#2416967
12/11/17 08:50 PM
12/11/17 08:50 PM
Posts: 17,916 Akron, Ohio
ProSport
Akron, Ohio
I've always just bumped the starter, I even have a starter button on the center of the firewall that I can reach from both sides. I use the 'ICE' method so once they're set I can buzz through them in a few minutes just to check them.
[Re: rowin4]
#2417031
12/11/17 10:40 PM
12/11/17 10:40 PM
[Re: Hemi_Joel]
#2417074
12/11/17 11:58 PM
12/11/17 11:58 PM
Posts: 9,791 MI, usa
dvw
MI, usa
I bump mine (15-1 comp) and do not follow the firing order. Switch is right on the firewall. Same stock Dodge truck starter for 5 years. Nearly 500 passes lashed every 20-25 passes. Doug
[Re: dvw]
#2417078
12/12/17 12:03 AM
12/12/17 12:03 AM
Posts: 20,116 PA.
pittsburghracer
I mounted a remote switch on both sides of the firewall on my Duster and have always used the starter to set valves. https://shop.advanceautoparts.com/p/auto...=starter+button
