Page 4 of 4 1 2 3 4
Re: SBM victor set up [Re: 420duster] #2418495
12/14/17 02:57 PM
12/14/17 02:57 PM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
I wish you guys all the best of luck with that Ritter block its not a money matter Kent has plenty of that he has all the connection to make a good block he just chose a cheaper way out Ryan from Shady Dell has a couple of those blocks running you might want to talk with Ryan
Re: SBM victor set up [Re: 69 lawndart] #2418497
12/14/17 03:01 PM
12/14/17 03:01 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
Originally Posted By 69 lawndart
At this point in time the aluminum Ritter block in mine has been great, no problems. WhiteDart are you feeding the oil into the motor on the front China wall? I drilled and taped the hole between the upper and lower oil gallies and put a restricter in to slow the oil down going to the top end. I am feeding mine through the back of the block.
when you say at this point in time.. is that because you have had bearing issues also??.. how many passes has it been happy.. mine is restricted at the bushing.. I thought you were running bushings as well
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: SBM victor set up [Re: 420duster] #2418834
12/15/17 02:10 AM
12/15/17 02:10 AM
Kansas, Topeka
69 lawndart Offline
69 lawndart  Offline
Kansas, Topeka
Yes sir I did have some bearing issues with bearings. I do not blame the block, I will take the blame for that mistake. There is 17 passes and about 1800 miles on it. Yes I did put bushings it. Please understand I'm not saying the block is perfect but it is usable, the first R3 block I got wasn't perfect either I had to do a lot of work to it.
Re: SBM victor set up [Re: 69 lawndart] #2418864
12/15/17 03:23 AM
12/15/17 03:23 AM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
That is great news..how fast has it went .. the aluminum block has my interest unfortunately I can't give him any more of my money..
Page 4 of 4 1 2 3 4
