whats the deal with this hole on SB heads #2413997
12/06/17 01:14 AM
12/06/17 01:14 AM
Valencia, España
NachoRT74 Offline OP
Valencia, España
what you read
and I have seen matching exhaust manifolds with this hole and some which doesn't have it
Re: whats the deal with this hole on SB heads [Re: NachoRT74] #2414000
12/06/17 01:20 AM
12/06/17 01:20 AM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
Those are for the smog pump. They can be tapped and plugged with Allen set screws.
Re: whats the deal with this hole on SB heads [Re: NachoRT74] #2414073
12/06/17 08:25 AM
12/06/17 08:25 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Correct.They are for emissions.Plugged lots of them.Rocky
Chrysler Firepower
Re: whats the deal with this hole on SB heads [Re: NachoRT74] #2414421
12/06/17 10:07 PM
12/06/17 10:07 PM
Valencia, España
Valencia, España
but why emissions... what they do on how they work ?
Re: whats the deal with this hole on SB heads [Re: NachoRT74] #2414435
12/06/17 10:21 PM
12/06/17 10:21 PM
Starting in the mid 70's there was a smog pump, belt driven, that would pump air into the exhaust via that hole that would combine with unburied fuel that would then burn in the exhaust.
You don't want it, you don't need it. Plug the holes.
Re: whats the deal with this hole on SB heads [Re: Pacnorthcuda] #2414949
12/07/17 10:19 PM
12/07/17 10:19 PM
dogdays Offline
dogdays  Offline
A I R air injection reaction An air pump, usualy sliding vane design, pumps air into the exhaust passages which help complete combustion of the unburned hydrocarbons and CO. They first appeared on chevies in about 1968 and were on some engines up through the beginning of three way catalytic converters. In order to get a three way converter to work the A/F ratio had to be controlled within a very narrow window and the AIR injection didn't fit the control scheme.
Some AIR systems ran tubes into the exhaust port. Some used a small hole in the exhaust port which was fed through an isolated port system in either the exhaust manifold or the intake. Pontiac and possibly other engines used the negative pulses in the exhaust ports to draw in air past reed valves The system you are mentioning cost virtually no horsepower but the belt for the pump was often removed in the name of more power. It was something to be done by the owner to improve performance, although the results were inconclusive.
The heads have the hole that runs straight from the exterior into the exhaust passage and there was a small bump to help mix the air. This hole is straight and usually has a lot of carbon in it. I was going to use older exhaust manifolds and so I plugged the holes. My plan was to use 1/4-20 screws so after getting the 1//4-20 tap I got the drill bit necessary ahd drilled the holes. I thin threaded the holes. The cast iron of the heads had some hard spots and I managed to break off a tap in one hole. I found eight short bolts and threaded themn into the holes, then cut off the bolt heads with a hacksaw. After I ccleaned the holes by drilling I could have also used JB Weld to plug the holes but the little bolts were free and were so low quality that I didn't want to use them anywhere else. You could probably plug them with oak pegs or RTV or many other things.
R.
Re: whats the deal with this hole on SB heads [Re: NachoRT74] #2415121
12/08/17 10:27 AM
12/08/17 10:27 AM
Valencia, España
Valencia, España
I was aware of the air pump setup ( which in fact I think is the reason on BB the steering pump was installed lower into the engine bay and water pump housing changed the lower outlet to the passanger side since 73 ), but never analized where or how was making the interaction. I recall they were conected to the carb, and not related to the exhaust system
Re: whats the deal with this hole on SB heads [Re: NachoRT74] #2415122
12/08/17 10:29 AM
12/08/17 10:29 AM
Valencia, España
Valencia, España
now wondering about this system on BB, since they don't have a similar setup on heads/exhaust manifolds, at least I have noticed
Re: whats the deal with this hole on SB heads [Re: NachoRT74] #2415405
12/08/17 08:48 PM
12/08/17 08:48 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Hey Nacho, Not sure what you mean by BB and in relation to the heads you posted??
Whether they are present depends on when the heads were made and for what engine. See for example: 1973 Chrysler Clean Air MTSC, Air Injection
As far as the purpose, Pacnorth has basically covered it. The air injection into hot exhaust helped consume unburned hydrocarbons and also reacted with CO.
For Chrysler products, cats came later. laugh2
You're lucky. On my first engine install, I didn't notice them until after firing it up. The guys in the exhaust shop pointed them out. Not much fun tapping and installing the setscrews afterwords but it was a learning experience. beer
Re: whats the deal with this hole on SB heads [Re: NachoRT74] #2415784
12/09/17 05:01 PM
12/09/17 05:01 PM
Valencia, España
Valencia, España
head is of course SB, not mine but a friend
wondering about why SBs got this an not BB ?
Re: whats the deal with this hole on SB heads [Re: NachoRT74] #2415889
12/09/17 08:45 PM
12/09/17 08:45 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Some did.
Re: whats the deal with this hole on SB heads [Re: NachoRT74] #2415894
12/09/17 09:00 PM
12/09/17 09:00 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
by the mid 70s went those showed up on the small blocks the BB were on their way out...stopped in 1978, they were only used in pickup trucks and RV which were allowed to run dirtier based on small laws.
Tony
70 AARCuda Vitamin C
71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield)
71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas)
71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
