Re: Mopar RB 572 1000 HP Project 1970 Cuda
[Re: Raffaplymouth60]
#2423013
12/24/17 07:23 AM
12/24/17 07:23 AM
Posts: 2,932 Finalnd, Perkele
jyrki
Finalnd, Perkele
C14 min. Don't ask me how I know... Engine sounds great though, bet it would idle a little lower than that... Not to appear pedantic but I think Europe uses a different way to rate octane numbers. IIRC I think 100 octane Europe is equivalent to 107 (ish) Stateside. Still not enough IMHO though. yep! i think 100 octane is around 106/107 US Gasoline .. idle is around 1300 RPM The Euroepan 98/99 octane is about 93 octane US. European gas is rated as RON octane, while US is (RON + MON)/2. Race gas is available, and it must be unleaded, we are using VP MS109 at the track and regular 95 in the street. Was a bit difficult to obtain MS109 in the states... The last barrell I bought cost 26.7$ a gallon. Dirt cheap!
Plynouth VIP '67 TT IC EFI
[Re: jyrki]
#2423016
12/24/17 09:18 AM
12/24/17 09:18 AM
Posts: 2,915 A shed in England
Tig
A shed in England
C14 min. Don't ask me how I know... Engine sounds great though, bet it would idle a little lower than that... Not to appear pedantic but I think Europe uses a different way to rate octane numbers. IIRC I think 100 octane Europe is equivalent to 107 (ish) Stateside. Still not enough IMHO though. yep! i think 100 octane is around 106/107 US Gasoline .. idle is around 1300 RPM The Euroepan 98/99 octane is about 93 octane US. European gas is rated as RON octane, while US is (RON + MON)/2. Race gas is available, and it must be unleaded, we are using VP MS109 at the track and regular 95 in the street. Was a bit difficult to obtain MS109 in the states... The last barrell I bought cost 26.7$ a gallon. Dirt cheap! Apologies to the OP for the Hijack, I usually use some 100LL avgas, I always thought this was MON rated only, and I always thought the ratings were the other way round (lower octane in the US). I guess everyday is a schoolday
[Re: D-50]
#2423137
12/24/17 04:06 PM
12/24/17 04:06 PM
Posts: 43,124 Bend,OR USA
I have never heard that about leaded or heard anybody EVER get their gasoline tested for lead. Glad I don't live in your state. The Fed EPA are the ones that made that regulation, not the states I use to use Aviation 100/115 in my M.W. car on the street years ago (pre 1980), lots of people would comment on the sweet exhaust smell even back then All leaded fuel sold today has a distinct different smell from any unleaded pump swill sold today
#2424319
12/27/17 12:12 PM
12/27/17 12:12 PM
an8sec70cuda
Raffa...unless you go REALLY conservative on the timing and kill power, you're going to need better fuel. 14:1 needs at least 112 octane IMO. Add nitrous and you'll need more than that. Like I said earlier, I'd be using VP C12 or C14 on motor only and at least VP C16 on the spray.
[Re: Cab_Burge]
#2424658
12/27/17 10:49 PM
12/27/17 10:49 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
I have never heard that about leaded or heard anybody EVER get their gasoline tested for lead. Glad I don't live in your state. The Fed EPA are the ones that made that regulation, not the states I use to use Aviation 100/115 in my M.W. car on the street years ago (pre 1980), lots of people would comment on the sweet exhaust smell even back then All leaded fuel sold today has a distinct different smell from any unleaded pump swill sold today That may be true but I still stand by my statement. I have never heard of anybody getting their fuel checked.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: an8sec70cuda]
#2427036
01/01/18 01:42 PM
01/01/18 01:42 PM
Posts: 195 Italy
Raffaplymouth60
Italy
Raffa...unless you go REALLY conservative on the timing and kill power, you're going to need better fuel. 14:1 needs at least 112 octane IMO. Add nitrous and you'll need more than that. Like I said earlier, I'd be using VP C12 or C14 on motor only and at least VP C16 on the spray. Hello Man ! yes .. from 10 years i use 100 octane for street use ( some time) and for race use with 350 spray.. i use 120 octane...im surprised by the old 496 with 12:1 when stop the engine was make lot of detonation with 100 octane... this 572 with 14:1 no detonation .. all time
1970 Cuda 496 street driven 9.22@150 1971 Demon 572 7.82@176 1957 Desoto Adventurer Convertible 345 Hemi 1958 Plymouth Fury Christine 2008 Dodge Ram 1500 Hemi 1970 Dodge ChallengerRT 6pack 4 speed 1 of 135 1968 Dodge Charger RT 4 speed
#2427151
01/01/18 03:42 PM
01/01/18 03:42 PM
Posts: 4,066 Mo.
racerx
Mo.
#2493266
05/07/18 04:28 PM
05/07/18 04:28 PM
Posts: 195 Italy
Raffaplymouth60
Italy
Hello guys .. first Race the last week end .. make 8 pass .. best time with 250 spray 9.6@149 only problem is bad 60 ft caused i think from converter ...engine dead at launch !
