Re: Paint Stripper
[Re: hemirdrnnr]
#2403843
11/15/17 03:19 AM
11/15/17 03:19 AM
Posts: 1,651 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
I'm using Aircraft Paint Remover now on steel wheels and body panels, and it's plenty strong and working very well. As long as you put it on thick, the paint will craze and lift up in a few minutes. It has a very strong ammonia odor, and it will chemically burn your skin pretty quick if you don't wash it off, so it's potent stuff.
My body and paint shop advised me to use Aircraft and to coat afterwards with Rust Cure or other phosphoric acid and wipe down with mineral spirits to lessen the acid residue.
Re: Paint Stripper
[Re: 71birdJ68]
#2403924
11/15/17 12:37 PM
11/15/17 12:37 PM
Silver70
Rust Belt, SW PA
Last time I bought some, it took a long long time to work and that was with roughing up the surface. It used to be if you got a tiny drop on you, you'd be running to the hose to wash it off... not you don't even know it's on you. Just another thing they made pretty much useless because of safety concerns.
