Re: 3.3 minivan coolant leak near trans cooler lines?
[Re: 360view]
#2401713
11/11/17 01:26 AM
11/11/17 01:26 AM
Posts: 954 garnett kansas
rhad
garnett kansas
most likely the plastic tank is cracked,i have seen them crack right by the crimp and it looks like the crimp is bad,you have to look close to see the crack
[Re: 360view]
#2401972
11/11/17 03:49 PM
11/11/17 03:49 PM
Posts: 3,372 St. Charles, MO
wingman
Uncreative Title
Uncreative Title
St. Charles, MO
Do a pressure check. We had that exact van and same problem I thought it was the radiator. Turns out the small hose to the overflow tank was leaking and causing the overflow tank to empty.
1969 Dodge Coronet Super Bee 383 A4 1970 Plymouth Road Runner 440 FC7 (sold)
[Re: 360view]
#2403231
11/13/17 09:11 PM
11/13/17 09:11 PM
Posts: 10,127 A Red State
SNK-EYZ
A Red State
The Mother in laws 2008 Grand Caravan had a coolant leak last year.
It ended up being one of the Y's that split the heater hoses for front and rear.
On her's they were on the drivers side at the firewall.
A Y shaped plastic tube, it split along a seam.
[Re: SNK-EYZ]
#2403380
11/14/17 02:33 AM
11/14/17 02:33 AM
rhad
garnett kansas
i repaired radiators for 37 years,my bet is still on a cracked plastic tank!!
[Re: 360view]
#2403391
11/14/17 03:04 AM
11/14/17 03:04 AM
I will rent a pressure tester. I didn't see this in time to offer a possible easier solution, You can buy a "tank valve" from Oreillys for less that $3 out the door & screw it into the cooling sender 1/8 NPT port & with an air chuck with shop air & a tire psi gauge pump the system up to 10 & see where it leaks from if external (hopefully not internal).
