#2401414 - 11/10/17 12:17 PM TQ plastic section
cudaman1969 Offline
Loc: fredericksburg,va
Anybody know what glue-epoxy is used to fix the jet wells back on to the Thermoquad bowl? (Where it sticks down into the base plate) White looking mixture from the factory.
#2401576 - 11/10/17 06:02 PM Re: TQ plastic section [Re: cudaman1969]
Loc: Bend,OR USA
I was told to use five minute epoxy years ago on anything in the cabs dealing with fuel, it worked up
#2401676 - 11/10/17 09:02 PM Re: TQ plastic section [Re: cudaman1969]
LAD 524 Offline
Loc: Oz
JB Weld wink
#2401684 - 11/10/17 09:20 PM Re: TQ plastic section [Re: cudaman1969]
SCATPACK 1 Offline
Loc: TN
JB weld dissolves in modern gas w alky. I used it on a gas tank where I added an additional outlet gas line. It lasted about 6 months and was completely loose.
Edited by SCATPACK 1 (11/13/17 12:39 PM)
Old Geezer Racing
#2401777 - 11/11/17 06:12 AM Re: TQ plastic section [Re: cudaman1969]
quickd100 Offline
Loc: nielsville, minn.
Try marinetex.
Speak softly and carry a BIG (605) STICK
#2401856 - 11/11/17 09:47 AM Re: TQ plastic section [Re: quickd100]
Dreaming of implants
Loc: north of coder
i was perusing the JB selection at the local ACE hardware the other day, and was surprised at the different formulas they have now for various applications. i think i saw a couple that stated they were impervious to gasoline, but i don't remember which formula they were.
#2402297 - 11/11/17 09:56 PM Re: TQ plastic section [Re: cudaman1969]
A/MP Offline
Loc: East Coast
Loctite Epoxy Bond and Moroso head epoxy. You need to create a mechanical tooth on all surfaces. Also don't worry only about ethanol in pump gas. The main culprit in pump gas is BTEX. Benzene,toluene, and xylene are cheap additives in most pump gas. Alone they attack plastics and gasoline hose. As a group they are very nasty.
#2402876 - 11/12/17 11:03 PM Re: TQ plastic section [Re: cudaman1969]
LAD 524 Offline
Loc: Oz
We have less corrosive fuel down here it seems wink
#2402931 - 11/13/17 08:36 AM Re: TQ plastic section [Re: cudaman1969]
A/MP Offline
Loc: East Coast
One note specifically about plastics. Some plastics are hard and others are soft. They all have have a vapor pressure that slowly breaks the chemical bonding. Everything is subject to it. Put that plastic in an environment that is subject to heat cycles and numerous petro chemicals and you will destroy it faster. Call Barry Grant. They are now making a TQ carb-3 BBL. See what they recommend for their phenolic bowl repair.
#2402997 - 11/13/17 10:46 AM Re: TQ plastic section [Re: cudaman1969]
Thumperdart Offline
Loc: State of confusion
I'v ground/filed the factory epoxy off and used JB Weld and never any issues........... thumbs
25,485 Registered Members
192,920 Topics
Was the light package standard on Mopar convertibles?
by Grassosgarage
09/19/18 12:38 AM
Monster Musclecar Weekend @ Gateway
by 71yelladustr
09/18/18 10:58 PM
Single feed vs. dual feed carb.
by 440mopar
09/18/18 10:41 PM
Wear can you get A-Body Rear Shackle Hangers?
by Hoop
09/18/18 10:06 PM
