Tranny front pump seal #2391091
10/22/17 10:02 AM
10/22/17 10:02 AM
1930 Offline OP
1930  Offline OP
Replaced the bushing and gears in my front pump, is it true that I should pack the gears with vaseline before putting it all back together?
Also
I know there is some type of sealer that Im supposed to use on the pump seal before I press it into the front pump housing but I dont know what kind.
I think alot of seals have a sealer embedded in the circumfrence of the seal already but mine does not appear to have anything although there is a very thin red coating and I understand that maybe thats all there is?
I ask cause the seal I took out has the same red coating but there ALOT more of it, so much that Ill have to clean the old dried up residue that still stuck to the inside of the pump flange.
Re: Tranny front pump seal [Re: 1930] #2391138
10/22/17 11:44 AM
10/22/17 11:44 AM
moparx  Offline
don't know about the sealer, but pack the back side of the seal where the spring is with vaseline to keep the spring from popping out. i learned this the hard way.......
Re: Tranny front pump seal [Re: 1930] #2391191
10/22/17 12:52 PM
10/22/17 12:52 PM
1930 Offline OP
1930  Offline OP
C-6 no spring but thanks
Re: Tranny front pump seal [Re: 1930] #2391361
10/22/17 06:49 PM
10/22/17 06:49 PM
John_Kunkel Offline
John_Kunkel  Offline
I've never seen a pump seal without a garter spring, look again.
Seals with a metal outer ring and flange are usually coated but I always add a thin coat of RTV. Seal with a rubber outer ring goes in dry.
Re: Tranny front pump seal [Re: 1930] #2391402
10/22/17 07:44 PM
10/22/17 07:44 PM
1930 Offline OP
1930  Offline OP
Thats what I done, thanks
Re: Tranny front pump seal [Re: 1930] #2391478
10/22/17 10:17 PM
10/22/17 10:17 PM
Mass.
8
80fbody Offline
80fbody  Offline
Mass.
Packing the pump gears would probably help get pressure up quicker. Not a bad idea.
