Hemi rear main seal replacement in car #2390499
10/20/17 09:09 PM
10/20/17 09:09 PM
clarks summit pa
73cuda340 Offline OP
clarks summit pa
The rear main seal is leaking in the hemi crate motor that I put in my cuda. Has anybody replaced one of these with the motor still in the car, or does it have to be pulled?
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip, (JA5) Silver Frost Metallic 1973 Challenger Rallye 340 1985 W150 Power Ram prospector 1986 Camaro IROC-Z 305 tpi
Re: Hemi rear main seal replacement in car [Re: 73cuda340] #2390578
10/20/17 11:22 PM
10/20/17 11:22 PM
RapidRobert Offline
RapidRobert  Offline
if you pull the center link etc & jack the eng up I would think the pan can be dropped. I think the rear main seal area is like a BB but here is a BTT for ya.
Re: Hemi rear main seal replacement in car [Re: 73cuda340] #2390591
10/20/17 11:43 PM
10/20/17 11:43 PM
Kirkland, Washington
Pacnorthcuda Offline
I've done two seals on two different 440 Cudas. As far as the center link, just disco the pitman and the idler (leave the tie rods alone), the assembly will swing down about 6 inches and give plenty of clearance.
Pretty easy as far as in-car oil pan removal.
Then you can break the mains and drop the crank just a bit, or try to do it without disturbing the crank, sometimes works, sometimes not. Clean and degrease the main seal sealing areas (where RTV does its job) REALLY well.
Re: Hemi rear main seal replacement in car [Re: 73cuda340] #2390687
10/21/17 05:09 AM
10/21/17 05:09 AM
Cab_Burge Online work
Cab_Burge  Online Work
Before you tear into the motor make absolutely sure where the oil is leaking from, it can leak from the rear main seal, one of or both of the rear oil galley plugs or the cam plug, the rear main seal holder can leak out of the sides alao looking like it is the seal when it isn't shruggy scope twocents One motor in particular the guy had the oil pan off four or five times before someone else saw both valve covers leaking from the rear corners dripping down onto both rear engine ears and then blowing back into the tranny dust sheild puke
I've seen more than one "main seal" oil leak turn out to be not that tsk
If it is the rear main seal itself leaking the oil will be slung off of the crank shaft flange onto the front of the flex plate or flywheel and then slung outwards leaving a distinct pattern of straight oil lines from the center of the crankshaft flange scope
Good luck, let us know what you find thumbs
Re: Hemi rear main seal replacement in car [Re: 73cuda340] #2390734
10/21/17 11:22 AM
10/21/17 11:22 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I've done the rear main seal on a HEMI in both B and E bodies in car, no different than doing a smallblock or B/RB, drop the center link, if your running a "stock" pan you shouldn't have to undo any motor mounts to raise the engine slightly, an aftermarket pan chances are you'll need to raise the engine off the mounts for removal depending on the sump/pick up design
FYI...it seems the crate HEMI's have a bad rep for rear main seals, don't be surprised if the lip is installed backwards
Re: Hemi rear main seal replacement in car [Re: DAYCLONA] #2390832
10/21/17 02:18 PM
10/21/17 02:18 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I've done them in the car twice, not that bad of a job. I don't know if I'm lucky or not but the side seals seem to give more trouble than the actual crank seals. Investigate first before tearing in.
Sheldon
Re: Hemi rear main seal replacement in car [Re: RUNCHARGER] #2392607
10/24/17 10:30 PM
10/24/17 10:30 PM
clarks summit pa
clarks summit pa
I ran the car and watched from underneath and I can see oil dripping from the crankshaft flange. There is oil slung all over the headers and now it's cooked on there
. The front seal seems to be leaking as well since I have oil leaking onto the k member and running along the oil pan rail. The motor starts to leak once it warms up, enough that there is a steady drip of oil. I'm very disappointed with it since its not one of the mopar performance crates; I ordered the motor straight from Ray Barton and it started leaking with less than an hour of run time.
