Re: Best paint for steel rims [Re: 360view] #2391134
10/22/17 11:40 AM
10/22/17 11:40 AM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
Originally Posted By 360view
Please resize or remove that Preval picture because it has made the text in this thread so small it is nearly impossible to read.
It didn't change my text size.
Removed for those that did.
Re: Best paint for steel rims [Re: Evil Spirit] #2391222
10/22/17 02:12 PM
10/22/17 02:12 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
Originally Posted By Evil Spirit
Originally Posted By larrymopar360
I'd love to be able to spray with gun and use automotive paint. But some of us don't have the facilities or equipment.
Have you looked into the Preval spray systems? They use a compressed air can, about the size of a butane refill, as a driver to spray the paint, which you mix and is contained in a jar below. Great way to apply automotive catalyzed paints on small jobs if you don't have access to a compressor and spray guns.
I have not, but I will now. Thanks!
Facts are stubborn things.
Re: Best paint for steel rims [Re: B5 Bee] #2391360
10/22/17 06:48 PM
10/22/17 06:48 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Originally Posted By B5 Bee
Originally Posted By crlush
Powdercoat
OK for a new rust free wheel, not an old with rust.
The reason is the same as the last sentance Neil's post above.
"If you do use paint pour primer + paint into the seams and swish it around. Where the center and hoop meet is where the rust will start first."
Paint can be poured in the seam but it is impossible to get the powder in the center/hoop seam to seal the fresh blasted metal.
When I went from 13" to 14" body color wheels on my '68 Valiant, I sprayed them with a 50/50 mix of satin and gloss black Rustoleum Enamel. The next weekend I scuffed the outside and sprayed it body color.
Old wheels blasted and powder coated 8 yrs ago,do it once and your done,only way to go !! twocents
Re: Best paint for steel rims [Re: B5 Bee] #2391408
10/22/17 07:59 PM
10/22/17 07:59 PM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
Thank you.
You were right, it was not that image because the text stayed small.
Re: Best paint for steel rims [Re: WO23Coronet] #2391577
10/23/17 01:15 AM
10/23/17 01:15 AM
Maryland
MoparMike1974 Offline
Maryland
I did my cop wheels with 2k epoxy then a coat of high build 2K primer. Most of the high build will be sanded off, I used it to fill small imperfections. After I sand the high build it will get another coat of epoxy primer. Last will be some 2K hot rod black which is a low sheen satin black.
