Re: Four Speed Overdrive Automatic
[Re: 451Mopar]
#2393117
10/25/17 10:24 PM
10/25/17 10:24 PM
Posts: 10,667 North Dakota
6PakBee
North Dakota
The J.W Performance Ultra Bell makes the conversion a bit easier. Hmm. The Ultra Bell looks interesting. The JVX reminds me of the Trans-Dapt adapters that used to pretty much adapt anything to anything. Looks like the current offerings are pretty slim.
[Re: DaveRS23]
#2393417
10/26/17 04:27 PM
10/26/17 04:27 PM
Posts: 1,574 Lakeland FL
floridian
Lakeland FL
Looks like the biggest down side to putting a GM based tranny in your Mopar is money. The GM based kits look to cost over a grand more than the Mopar based stuff. That would be the first time ever a GM part was more money than Moparts...
[Re: 6PakBee]
#2393663
10/27/17 02:34 AM
10/27/17 02:34 AM
Posts: 4,369 Michigan
MarkZ
Worthy
Worthy
The J.W Performance Ultra Bell makes the conversion a bit easier. Hmm. The Ultra Bell looks interesting. The JVX reminds me of the Trans-Dapt adapters that used to pretty much adapt anything to anything. Looks like the current offerings are pretty slim. Ultra Bell is the way to go. Just used one to bolt a 46RH behind a 512 stroker. Nothing special done to the transmission either other than a re-freshening. Seems to be holding up just fine.
[Re: MarkZ]
#2393762
10/27/17 12:09 PM
10/27/17 12:09 PM
6PakBee
North Dakota
Ultra Bell is the way to go. Just used one to bolt a 46RH behind a 512 stroker. Nothing special done to the transmission either other than a re-freshening. Seems to be holding up just fine. So you cut back to the edge of the front pan rail? From the Ultra Bell literature it locates off the front pump. Does it fit over the face of the pump? Do you have to dial it in like you would a manual bell housing? It's shame you didn't have a picture from the front with the bell installed. That looks clean.
[Re: 6PakBee]
#2393776
10/27/17 12:35 PM
10/27/17 12:35 PM
Posts: 2,843 Pattison Texas
CSK
Pattison Texas
Here is mine I put behind my 512,
[Re: CSK]
#2393792
10/27/17 01:02 PM
10/27/17 01:02 PM
6PakBee
North Dakota
Here is mine I put behind my 512, So the machined surface of the Ultra Bell bolts up against the as-cast face of the front pump. Wouldn't you run into some parallelism issues as the front pump face isn't a machined surface?
[Re: 6PakBee]
#2393926
10/27/17 06:59 PM
10/27/17 06:59 PM
CSK
Pattison Texas
Here is mine I put behind my 512, So the machined surface of the Ultra Bell bolts up against the as-cast face of the front pump. Wouldn't you run into some parallelism issues as the front pump face isn't a machined surface? the front side of the pump is machined, the JW bell is made for many applications, it is used on MANY race,street cars with no problems.
[Re: CSK]
#2394179
10/28/17 11:32 AM
10/28/17 11:32 AM
6PakBee
North Dakota
Here is mine I put behind my 512, So the machined surface of the Ultra Bell bolts up against the as-cast face of the front pump. Wouldn't you run into some parallelism issues as the front pump face isn't a machined surface? the front side of the pump is machined, the JW bell is made for many applications, it is used on MANY race,street cars with no problems. Thank you for setting the record straight. I was just confused.
