Re: Small block help [Re: LA360] #2391241
10/22/17 02:36 PM
10/22/17 02:36 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Originally Posted By LA360
Rob Goss is running a solid cast block with Billet heads. The same block is available with water jackets. They certainly broke a lot of parts working out what worked or not.
There are many options here really, a 9.2" or 9.6" deck R3 with a W series head
A Ritter or EEI block with P7 heads
A Gen III Hemi, factory block and heads will get it done. You can can spring for a pair of Thitek heads and Aluminium block from BES
I believe Goss is running a billet block from across the pond as stated in an interviewI posted.
GOTBOOST!New improved with Victor heads.
http://www.enginelabs.com/mopar-big-bloc...t-of-necessity/
Re: Small block help [Re: jkwedge540] #2391513
10/22/17 10:58 PM
10/22/17 10:58 PM
in front of the computer
8
80arrow Offline
80arrow  Offline
I thought Goss was running a HHP block
Re: Small block help [Re: jkwedge540] #2391672
10/23/17 10:49 AM
10/23/17 10:49 AM
CJD AUTOMOTIVE Offline
I'd suggest a tall deck R3 (or Ritter if brave) for sure to keep the R/S angle decent. Your stroking it, so your RPM will be limited, so 59* is fine. Yes, roller lifters work fine in these with a little clearance work. The new Eddy Victor heads would top it off nicely. Pedestal and shaft rockers are available for these from Crower, T&D, etc.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
www.CJDAUTOMOTIVE.com
904-400-1802
"I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
