Re: Do you use a pcv valve?
[Re: Adam71Charger]
#2389467
10/18/17 07:32 PM
10/18/17 07:32 PM
Posts: 2,842 Pattison Texas
CSK
Pattison Texas
I use breathers on my street car. I also change the oil & filter at 1k, without pcv ,moisture can build up, so far I have not seen any when I adjust the valves.
[Re: CSK]
#2389507
10/18/17 09:04 PM
10/18/17 09:04 PM
Posts: 338 Montreal Quebec
STROKIE
Montreal Quebec
I use breathers on my street car. I also change the oil & filter at 1k, without pcv ,moisture can build up, so far I have not seen any when I adjust the valves. I use two breather on my street and strip car too... Pcv reintroduce oil fumes into the engine and I think it's not the best octane booster.. I agree pcv is good for everyday car
[Re: AndyF]
#2389530
10/18/17 09:35 PM
10/18/17 09:35 PM
Posts: 43,007 Bend,OR USA
You should use a PCV on a street car. I do, always Moisture will condensate in your motor when sitting over night, the heat from the motor oil warming up the oil will help turn that moisture into steam (hot air rises)which the PCV will suck out removing it from the oil helping keep the oil in better, useable condition
[Re: Adam71Charger]
#2389640
10/19/17 12:28 AM
10/19/17 12:28 AM
Posts: 8,192 fredericksburg,va
cudaman1969
fredericksburg,va
Pretty much every engine up to the early 60s emissions era did not use them. Just had a pipe that turned down from a stand pipe on the valve cover, the old push on covers, vented to air. Either way engine must be vented. A good barometer on how the engine is lasting, no blow by, good, a lot, time for overhaul.
[Re: cudaman1969]
#2389670
10/19/17 01:11 AM
10/19/17 01:11 AM
Posts: 1,651 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
Pretty much every engine up to the early 60s emissions era did not use them. Just had a pipe that turned down from a stand pipe on the valve cover, the old push on covers, vented to air. Either way engine must be vented. A good barometer on how the engine is lasting, no blow by, good, a lot, time for overhaul. Yes, a good tell tale of engine condition. Remember back then how at red lights the air would fill with blow by from some of the high mileage (over 50,000) cars waiting for green?
[Re: cudaman1969]
#2389681
10/19/17 01:50 AM
10/19/17 01:50 AM
[Re: Adam71Charger]
#2390354
10/20/17 05:01 PM
10/20/17 05:01 PM
The better PCV do need a minimum, how much I don't, vacuum to keep them open. The cheaper ones will stay open most of the time when the motor is running All of them I've seen and cleaned have a check ball and spring to close the ball when the motor is not running, not all of them will seal up when not held open by vacuum
[Re: nasty68]
#2392587
10/24/17 10:12 PM
10/24/17 10:12 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
So a pcv valve on one side and a breather on the other side would be a good set up for the street? Yes. Ron
[Re: 383man]
#2392962
10/25/17 04:37 PM
10/25/17 04:37 PM
Posts: 15,193 Omaha Ne
TJP
Omaha Ne
[Re: Adam71Charger]
#2393011
10/25/17 06:40 PM
10/25/17 06:40 PM
Posts: 21,050 Niles , Ohio
therocks
Niles , Ohio
I run 2 breathers on my 440 The M1 and Dominator have no provisions for vacuum.Been like that for at least 15 years My son also ran 2 breathers on the 62 300 when he had it.Never a problem with it either and it had the OE motor.We just replace the draft tube when he put the cam in and drove thousands of miles.Rocky
Chrysler Firepower
