Mega blocks, some different quality?
#2389161
10/18/17 07:35 AM
10/18/17 07:35 AM
Posts: 9,963 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I bought a mega block way back in about 2,000 (AD!) Any body know of differences in quality over the years they were cast? I don't here much about some of the issues I have had, like cap walk and cylinder bank to bank flex? I got around both, ccw crank for the caps, no gasket, used silicone for intake sealing.
Re: Mega blocks, some different quality?
[Re: 451Mopar]
#2389346
10/18/17 03:21 PM
10/18/17 03:21 PM
Posts: 4,539 Motor City
6PKRTSE
Motor City
My Hemi 4.500" Bore block is an 07'ish vintage. No casting or machining issues at all with mine during the machining process other then our machine shop complaining how they chewed up tooling & had to slow down the speed & feeds of all of our machines due to the higher/better nickel content within the cast iron. They were all amazed when compared to the 1000's of Dart/World & other aftermarket & stock blocks we machine.
[Re: gregsdart]
#2389393
10/18/17 04:43 PM
10/18/17 04:43 PM
Posts: 19,304 Las Vegas
Al_Alguire
Las Vegas
All of the Mega/World block I have used and been involved with ALL showed signs of cap walk and main bearing wear. The single best change we made was switching to a center counter weighted crank..But what do I know.
[Re: Al_Alguire]
#2389540
10/18/17 09:52 PM
10/18/17 09:52 PM
gregsdart
All of the Mega/World block I have used and been involved with ALL showed signs of cap walk and main bearing wear. The single best change we made was switching to a center counter weighted crank..But what do I know. Same hear on the crank. My block has no extra stiffening ribs in the valley, and it sucked gaskets in so I went silicone, no gasket. I run injection, so if it leaks, it isn't as hard to deal with. Haven't had issues yet though.
[Re: Al_Alguire]
#2390128
10/20/17 12:57 AM
10/20/17 12:57 AM
hemi-itis
I've broken two, both were the pre world versions does that count Not with the power your playing with!
[Re: gregsdart]
#2390639
10/21/17 01:42 AM
10/21/17 01:42 AM
Al_Alguire
Las Vegas
They were actually both the older casting ones as well. Non stiffening rib versions like DVM posted..Had to go back and look at the pics..
