who sells valves for w-2 heads? #2388300
10/16/17 06:59 PM
10/16/17 06:59 PM
alaska,usa
9
9secondsatellite Offline OP
alaska,usa
looking for 2.08 and 1.6 3/8" stem valves for a set of w-2 heads. the mopar numbers are p5249196 and p5249197 which a discontinued. found a set from ferrea which will work. anyone else sell these types of valves?
Re: who sells valves for w-2 heads? [Re: 9secondsatellite] #2388470
10/16/17 11:30 PM
10/16/17 11:30 PM
East Coast
A/MP Offline
A/MP  Offline
East Coast
Ferrera
Re: who sells valves for w-2 heads? [Re: 9secondsatellite] #2388706
10/17/17 01:06 PM
10/17/17 01:06 PM
fast68plymouth Offline
Ferrea has them...... Or, if you wanted to lighten things up, install guides so you can run 11/32" stem valves....... Then there are a lot more options for valves.
Re: who sells valves for w-2 heads? [Re: fast68plymouth] #2388734
10/17/17 02:07 PM
10/17/17 02:07 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
iagree
If you're going to put new guides in anyway, the lighter/smaller 11/32's are eaiser to find.
WIZE
World's Quickest Diahatsu Rocky (??) 414" Stroker Small block Mopar Powered. 10.84 @ 123...and gettin' quicker!
https://www.youtube.com/watch?v=-mWzLma3YGI
In Car:
https://www.youtube.com/watch?v=PjXcf95e6v0
Re: who sells valves for w-2 heads? [Re: 9secondsatellite] #2388747
10/17/17 02:31 PM
10/17/17 02:31 PM
P
Porter67 Offline
Porter67  Offline
P
If your looking at the Ferrea valves, put some thought in the 5000 vs 6000 series.
One set is 2x the other and in most cases the 5000 series are more then enough and lighter as well over the 6000.
If it was sprayed or boosted id consider the 6000 series, at least for the ex. valve.
Re: who sells valves for w-2 heads? [Re: Porter67] #2388796
10/17/17 03:53 PM
10/17/17 03:53 PM
dogdays Offline
dogdays  Offline
Why stop at 11/32? Hemis run 5/16" valve stems, which is spitting close to 8mm, a common size for metric engines. I'm thinking I have seen some used NASCAR valves with 6mm stems.
R.
Re: who sells valves for w-2 heads? [Re: 9secondsatellite] #2388922
10/17/17 07:49 PM
10/17/17 07:49 PM
alaska,usa
9
alaska,usa
thanks for all of the input guys. the seats and guides(3/8) are new and was trying to get the cost down for such a basic build. i thought about going to chevy .300 longer as an option but that would entail new guides and then new valve job. the ferrea valves with 3/8 stems were about $28 a piece so then that adds up after that. the only 5000 series were available only in the exhaust and not the intake. i need the long valves for this application or the choices would have been more abundant.
Re: who sells valves for w-2 heads? [Re: 9secondsatellite] #2389197
10/18/17 10:48 AM
10/18/17 10:48 AM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
Originally Posted By 9secondsatellite
...i need the long valves for this application or the choices would have been more abundant.
I'm with you on this one...the long valve version is actually very difficult to find, at least from the information I have available I'm in the same boat you are.
The difference is that I am willing to have new guides put it and go to a 11/32 stem, although, the W2 Econo Long heads I have here are brand new, never been used before, so quite honestly I have no idea if it actually makes sense to put new guides in, other than as a necessity to get me to an available valve stem.
Anyways, OK, so the closest off-the-shelf valves I found are the following Manley pieces:
1) 11702-8, 5.240" long, 2.02" diameter, 11/32 stem
2) 11703-8, 5.255" long, 1.60" diameter, 11/32 stem
Their tech I have been emailing with also suggested that I use "+.050" locks"...ughhh??? So I asked for further explanation:
"...The "tang" on the ID of the lock (part that "locates" in the keeper groove of the valve) is moved down .050" from its normal position......which allows the lock to sit higher up on the valve.....which, in turn, effectively raises the retainer (and valvespring) up that same .050".......thus, giving you .050" more (taller) installed height..."
So my current plan is to use these valves and the +0.050" locks to get me to that nearly matching dimension of the original MP valves you meantioned.
If there is a better way I would absolutely LOVE to know about it...pls post a valve part# though!
Re: who sells valves for w-2 heads? [Re: 9secondsatellite] #2389217
10/18/17 11:37 AM
10/18/17 11:37 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
If you look around enough I think you probably could find the Mopar valves although they will not be much less than the Ferrea.
Bill
Re: who sells valves for w-2 heads? [Re: 9secondsatellite] #2389456
10/18/17 07:08 PM
10/18/17 07:08 PM
Sullivan, IN
Mopar Sam Offline
Mopar Sam  Offline
Sullivan, IN
9secondsatellite, I sent you a PM.
