2002 Dodge Viper racecar vs 1973 Plymouth Duster pro touring #2355926
08/18/17 10:13 AM
08/18/17 10:13 AM
Houston Tx
Uhcoog1 Offline OP
Uhcoog1  Offline OP
Houston Tx
A few buddies and I rented Texas World Speedway on Tuesday morning. I took the 2002 Dodge Viper ex-world challenge car. Laid down a couple 1:52's.
Video:
My best time in the Duster was a 2:03. That video below.
I've wondered in the past what a pro touring car like my Duster was giving up, looks like 'about 10%' was the right answer.
-'02 Dodge Viper Ex-World Challenge racecar
-'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
Re: 2002 Dodge Viper racecar vs 1973 Plymouth Duster pro touring [Re: Uhcoog1] #2355928
08/18/17 10:28 AM
08/18/17 10:28 AM
Houston Tx
Uhcoog1 Offline OP
Uhcoog1  Offline OP
Houston Tx
2002 Viper specs for that run:
3350 lb with full load of fuel and driver
Full cage, stiffened chassis
Triple adjustable penskes- on base setting - no tuning done yet
18x13 with full tread Nitto NT01's: 335/30/18 square
Dyno from 12 years ago was 530 rwhp on dyno jet
1973 Duster specs for that run:
3840 lb with 2/3 load of fuel and driver
4 point roll bar, minimal stiffening (subframe connectors, XV radiator crossmember)
Bilstien RCD shocks. 1.04 TB's, 0" arch MP leafs, custom front sway, hellwig rear
18x9.5 with Hoosier Continental slicks: 285/30/18 square
Dyno not run with 392, but assumed 480 rwhp based on prior #'s from 5.7 dyno (420)
The Viper is significantly easier to drive.
Re: 2002 Dodge Viper racecar vs 1973 Plymouth Duster pro touring [Re: Uhcoog1] #2356056
08/18/17 02:15 PM
08/18/17 02:15 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Looks like it's time to get creative in the weight loss dept. for the Duster, 500 lbs is quite a large penalty. eek
Re: 2002 Dodge Viper racecar vs 1973 Plymouth Duster pro touring [Re: Uhcoog1] #2356062
08/18/17 02:37 PM
08/18/17 02:37 PM
Supercuda Offline
Supercuda  Offline
While we are looking at weight, keep in mind relocating required stuff to more advantageous places.
Don't be the exception.
Re: 2002 Dodge Viper racecar vs 1973 Plymouth Duster pro touring [Re: Uhcoog1] #2356165
08/18/17 06:19 PM
08/18/17 06:19 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
that's pretty good to only give up 10% to the viper.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: 2002 Dodge Viper racecar vs 1973 Plymouth Duster pro touring [Re: Supercuda] #2356166
08/18/17 06:21 PM
08/18/17 06:21 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
It's a race car VS "Pro Touring" as well. If you gut the street car it's a better race car and a worse street car. If "Pro Touring" is more Weekend/Track than cruiser, strip it down and get some ear plugs. As I've gotten older and tinnitus has gotten worse, I want some sound deadener and even A/C.
Re: 2002 Dodge Viper racecar vs 1973 Plymouth Duster pro touring [Re: Uhcoog1] #2356368
08/19/17 01:47 AM
08/19/17 01:47 AM
AndyF Offline
AndyF  Offline
Tim's red Valiant would hang with Vipers and Z06 Vettes at Portland International but his car was 3450 lbs with driver. With the 427 inch small block he had roughly the same power as an early Viper. Roughly 550 hp at the crank.
Re: 2002 Dodge Viper racecar vs 1973 Plymouth Duster pro touring [Re: AndyF] #2356467
08/19/17 10:51 AM
08/19/17 10:51 AM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
The Red Brick was/is a well sorted car driven by somebody that put in a lot of seat time. That weight is a about 400 lbs lighter than the '73 Duster in the OP, too. work
Re: 2002 Dodge Viper racecar vs 1973 Plymouth Duster pro touring [Re: Uhcoog1] #2356756
08/19/17 08:09 PM
08/19/17 08:09 PM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
Here's what the scales look like on Tims car with a full tank of gas, and the 2nd pic is with the driver.
Re: 2002 Dodge Viper racecar vs 1973 Plymouth Duster pro touring [Re: Uhcoog1] #2356774
08/19/17 08:34 PM
08/19/17 08:34 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
This makes the Duster look good lol! If it had the Vipers tires I bet it would get under 2 min.
Mopar to the bone!!!
Re: 2002 Dodge Viper racecar vs 1973 Plymouth Duster pro touring [Re: NV69B7RR] #2356853
08/19/17 11:04 PM
08/19/17 11:04 PM
AndyF Offline
AndyF  Offline
Tim's car has gained a little weight since the last time I weighed it!
Re: 2002 Dodge Viper racecar vs 1973 Plymouth Duster pro touring [Re: Uhcoog1] #2356856
08/19/17 11:07 PM
08/19/17 11:07 PM
AndyF Offline
AndyF  Offline
Here it was with driver back in the day.
This picture was taken in 2010 so I'm not 100% sure what changes we made to the car after that. We were in the process of changing the front suspension design around then so some weight could've moved around.
Re: 2002 Dodge Viper racecar vs 1973 Plymouth Duster pro touring [Re: Uhcoog1] #2356859
08/19/17 11:14 PM
08/19/17 11:14 PM
AndyF Offline
AndyF  Offline
Okay, found this picture that was taken at the same time. So this shows the wheels and tires that were on the car when we weighed it.
I looked thru my photos and it appears that this weigh in was BEFORE we installed the 427 so that could account for the weight difference. The 427 engine has the super heavy race block so it was heavier than the 360 block that was in there before.
Re: 2002 Dodge Viper racecar vs 1973 Plymouth Duster pro touring [Re: Uhcoog1] #2367512
09/08/17 04:00 PM
09/08/17 04:00 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
I can attest to the fact that Tim's old car could hang with a viper, I drove it at Spokane Raceway on track day and was right on the heels of a GenIII Viper for several laps, we were not allowed to pass but I think I could have given him a run in some sections of the track. Viper coupe was stock with track tires and an amateur, but pretty good driver, Valiant had those same wheels as Andy's pic with street legal (but mostly slick) rubber.
Re: 2002 Dodge Viper racecar vs 1973 Plymouth Duster pro touring [Re: Uhcoog1] #2367814
09/09/17 10:18 AM
09/09/17 10:18 AM
USA
Consulier Offline
Consulier  Offline
USA
Wade's review is good because it's the same driver in each car. Comparing anything against another car with a different, particularly unknown, driver is not a good comparison.
There is a video online of me at Sears Point a couple years ago lapping and passing some Porsches, Vettes, a GTR and a McLaren. I was driving a Chevy SS with an automatic out of the press pool. You can see how much the driver can skew the perception of speed and car ability.
