Re: Speedo Error
[Re: DougR]
#2326611
06/25/17 09:56 PM
06/25/17 09:56 PM
I would get a rear tire valve stem at 6 0'clock in a parking lot & roll the car straight forward till the stem is back at 6 0'clock (~8 ft) & tape measure that "rollout" distance then divide Pi (3.1416) into that # to get your exact tire diameter. I'm sure you know if those gears are 2.76's or not. you might also go out on the interstate & go past 4 or 5 mile markers & see if your ODO is correct cuz if the axle gears/speedo pinion teeth are correct then the odo must read correct & the prob is in the magnetic speedo head gismo & it needs to be sent to a specialty shop to be recalibrated but my gut tells me something else is wonky here. post how it goes. GPS would solve this or if you see a portable lighted digital roadside sign or if you see a cop parkedon the side of the road ask him if he will clock you! have it a steady easy to read MPH when you pass him such as 40 or 50 etc. post how it goes/what it ends up being.
Re: Speedo Error
[Re: DougR]
#2326858
06/26/17 11:10 AM
06/26/17 11:10 AM
gear ratio good. tire dia good (& putting a piece of stock across the top of the tire then measureing underneath it down to the ground will get you real close, & will for sure tell you that that part is OK & as you said I'm sure it is). GPS dont lie. all that is left is a misprint in the tooth selection chart. we need 26% more teeth (37.8) so the 38 you mentioned would be very near dead on. Just me I would do rollout while you're at it as it might bump you to 37 or tell you 38 would be dead on. I jack the left side up higher than needed to minimize fluid loss. EDIT tho going to the low side (37) might save you a ticket from an overzealous cop.
