Re: Making an internal balance flywheel work on a stock 360...
[Re: dogdays]
#2295928
04/29/17 04:00 AM
04/29/17 04:00 AM
Posts: 4,862 the frozen wastes...
Pale_Roader
Swears too much
Swears too much
Cheapo trick from chevy racers back in the day... Sandwich the 5.9 Mag flexplate behind the neutral balance flywheel. Voila! Done
Slightly more expensive: Get the 360 add-on weight and drill it to reduce the amount of imbalance. I believe with the MP drawings you can figure out what angle and how much to remove.
R. Or one could possibly get both parts, and use the flexplate as a template/guide for modifying the smaller pie piece. Hmmm... Either way i go, shouldn't be too hard to figure out.
[Re: Pale_Roader]
#2296130
04/29/17 03:23 PM
04/29/17 03:23 PM
Posts: 25,618 Rio Linda, CA
John_Kunkel
He says "They'll work" on a Magnum 360. When i mentioned the slight balance/bobweight differences he said 'Its close enough". Says "people run it all the time". Gosh, that's reassuring.........not.
[Re: John_Kunkel]
#2296371
04/30/17 03:19 AM
04/30/17 03:19 AM
Pale_Roader
Swears too much
Swears too much
He says "They'll work" on a Magnum 360. When i mentioned the slight balance/bobweight differences he said 'Its close enough". Says "people run it all the time". Gosh, that's reassuring.........not. Well... this guy builds more HP engines in a week than i'll build my entire life... so his guess is probably worth more than my math. But yeah... there's that little instinct...
[Re: Pale_Roader]
#2296376
04/30/17 03:27 AM
04/30/17 03:27 AM
Posts: 43,007 Bend,OR USA
