Re: Anyone run Ford TFI coil+HEI module with mopar distributor?
[Re: mopower440]
#2661848
06/03/19 12:58 PM
06/03/19 12:58 PM
Posts: 17,838 S.E. Michigan
ZIPPY
S.E. Michigan
The 4 pin module is really the one to use with this basic swap, where you're carbureted and are controlling advance with a mopar distributor.
I have not researched this to death and don't feel I know all the ins and outs of it, but I believe the 7 pin or 8 pin module is still useful... I believe it is the one you want to use with EFI/megasquirt with the computer providing spark control.
Rich H.
Esse Quam Videri
[Re: mopower440]
#2669990
06/25/19 10:36 PM
06/25/19 10:36 PM
Posts: 1,807 North Dakota
Azzkikrcuda
North Dakota
If you like to mount the module off the distributor like I do to get it away from some heat. Try this bracket, AC Delco #10474610. Just drill 2 new holes and it works great and is under $20.
The only Carbs I care about are under the hood!
[Re: Azzkikrcuda]
#2670075
06/26/19 08:17 AM
06/26/19 08:17 AM
Posts: 2,863 middle Tennessee
mopower440
middle Tennessee
If you like to mount the module off the distributor like I do to get it away from some heat. Try this bracket, AC Delco #10474610. Just drill 2 new holes and it works great and is under $20. I like that!
[Re: mopower440]
#2670082
06/26/19 08:43 AM
06/26/19 08:43 AM
Posts: 1,317 Ohio
jlatessa
Ohio
You can mount the module on the back of the heat sink and not have to drill any extra holes. Used long through-screws to get the necessary clearance for mounting to fender housing.
Joe
PS, don't forget the paste for heat transfer
[Re: Azzkikrcuda]
#2670108
06/26/19 09:49 AM
06/26/19 09:49 AM
ZIPPY
S.E. Michigan
That heat sink is a nice addition, thank you!
I'm thinking a couple stand offs for mounting would help the heat situation even more.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2670153
06/26/19 11:53 AM
06/26/19 11:53 AM
would it be better to have it mounted flush with some heat sink paste to wick away heat produced in the module (like it is in the HEI dist) or to space it up to isolate it from heat in this metal mounting bracket itself?
