Re: Distributor Cam Gear?
[Re: Blucuda413]
#2277185
03/27/17 03:05 PM
03/27/17 03:05 PM
Posts: 43,097 Bend,OR USA
I know it's a no-no to use anything but a nice brass gear for solid roller lifters but is there anything wrong in using the same brass gear with flat tappet solid lifters? Don't do that Use a stock OEM drive
[Re: Blucuda413]
#2277186
03/27/17 03:05 PM
03/27/17 03:05 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I know it's a no-no to use anything but a nice brass gear for solid roller lifters but is there anything wrong in using the same brass gear with flat tappet solid lifters? I dont know.. but I will find out.. thats what I have in it now
[Re: Cab_Burge]
#2277190
03/27/17 03:11 PM
03/27/17 03:11 PM
MR_P_BODY
I know it's a no-no to use anything but a nice brass gear for solid roller lifters but is there anything wrong in using the same brass gear with flat tappet solid lifters? Don't do that Use a stock OEM drive Cab.. what is the reasoning for this.. my thoughts were that you didnt use the OEM on the roller due to the hardness of the cam and it pounding back and forth on the lobes(as it came off the lobes)
[Re: MR_P_BODY]
#2277208
03/27/17 03:50 PM
03/27/17 03:50 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
What I have been doing lately is rounding the edges on the camshaft gear itself . And this process has greatly added to the life of distributor gear... a lot of times the cams have very sharp edges..
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: WHITEDART]
#2277264
03/27/17 05:19 PM
03/27/17 05:19 PM
MR_P_BODY
What I have been doing lately is rounding the edges on the camshaft gear itself . And this process has greatly added to the life of distributor gear... a lot of times the cams have very sharp edges.. Are you talking a roller cam and bronze gear.. I have a solid flat tappet and bronze gear.. I didnt have any stock gears laying around so I uses a bronze that was on the shelf.. it was new.. it has a couple hundred miles on it
[Re: MR_P_BODY]
#2277500
03/28/17 02:10 AM
03/28/17 02:10 AM
WHITEDART
bean town ....Ca
What I have been doing lately is rounding the edges on the camshaft gear itself . And this process has greatly added to the life of distributor gear... a lot of times the cams have very sharp edges.. Are you talking a roller cam and bronze gear.. I have a solid flat tappet and bronze gear.. I didnt have any stock gears laying around so I uses a bronze that was on the shelf.. it was new.. it has a couple hundred miles on it you will be fine.. check out the cam see if the edge of the gear is sharp.if so just take the edge of
[Re: WHITEDART]
#2277505
03/28/17 02:18 AM
03/28/17 02:18 AM
MR_P_BODY
What I have been doing lately is rounding the edges on the camshaft gear itself . And this process has greatly added to the life of distributor gear... a lot of times the cams have very sharp edges.. Are you talking a roller cam and bronze gear.. I have a solid flat tappet and bronze gear.. I didnt have any stock gears laying around so I uses a bronze that was on the shelf.. it was new.. it has a couple hundred miles on it you will be fine.. check out the cam see if the edge of the gear is sharp.if so just take the edge of Its in there.. I did touch the edges of the gear when I put it in.. thanks
[Re: Dave Hall]
#2278015
03/28/17 09:46 PM
03/28/17 09:46 PM
MR_P_BODY
If the roller cam gear is bronze, don't you want a like metal gear to mesh with it? Same is true the other way around? It's all antiquated engineering now. Everything uses belts. There are ways to not run gears in the engine. Well its in there and will run till it starts to fail.. at that time I will change.. till then its a test
