Re: 1969 B body rear assembly problems HELP [Re: RapidRobert] #2277206
03/27/17 03:50 PM
03/27/17 03:50 PM
Supercuda Offline
Supercuda  Offline
Originally Posted By RapidRobert
You can swap sure grip & non sure grip pigs & nothing changes on the axles so it would have to be non axle related.
Early 8 3/4's, with two piece axles, do have different lengths between SG and non-SG applications. But that's not what the OP has (I hope).
Don't be the exception.
Re: 1969 B body rear assembly problems HELP [Re: mro] #2277215
03/27/17 04:03 PM
03/27/17 04:03 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Originally Posted By mro
- axles 29 1/4, buttons in place, 489 case, any ideas ?
What sure grip do you have , the case don't matter unless you know for a fact that it has never been messed with .
489 would have come from the factory with a Cone type , no buttons , just a thrust block that can't fall out.
Clutch type has buttons and they can fall out when the axles are pulled, the roll pin is an assembly aid , after many thousands of corner turns it will eventually break , it's not a potential problem till an axle is pulled.
What sure grip does it have ?
Re: 1969 B body rear assembly problems HELP [Re: mro] #2277238
03/27/17 04:37 PM
03/27/17 04:37 PM
Lynch Road
mro Offline OP
mro  Offline OP
Lynch Road
It came out of a 1971 cuda - 3.55 - unmolested - 489 case
68 Satellite Wagon and a few other ones
Re: 1969 B body rear assembly problems HELP [Re: mro] #2277274
03/27/17 05:59 PM
03/27/17 05:59 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Different length axles for open and SG are 1964 and older with the tapered axle & nut.
Re: 1969 B body rear assembly problems HELP [Re: mro] #2277640
03/28/17 12:14 PM
03/28/17 12:14 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Then it's a puke cone type ... No buttons, just a thrust block that can't come out unless the sure grips is completely disassembled.
