Re: Valve springs: Why must they be compressed down to .050 ?
[Re: hemienvy]
#2255081
02/17/17 04:17 PM
02/17/17 04:17 PM
Posts: 43,007 Bend,OR USA
Research and development by racers and race valve spring companies I've been told by several different cam companies to shoot for between .060 to .080 from coil bind on any solid roller valve springs, I've used those suggestions for years now Some things that we justify in our minds, especially on race parts, don't make it true Spurgoen Goins years ago, who owned AFR at that time , told me to compress every valve spring within .100 of coil bind in a vice and let it sit for at least 4 hrs. to allow the spring to "normalized" He was doing contract work for GM and Jr. Johnsons NASCAR team on the valve train and cylinder heads at that time
[Re: hemienvy]
#2256861
02/20/17 10:31 PM
02/20/17 10:31 PM
Posts: 11,889 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I have always heard that spring failure rates go way up as you get into that last little bit before bind due mostly to much higher heat build up and, of course, stress.
Any truth to that?
Master, again and still
[Re: hemienvy]
#2256907
02/21/17 12:01 AM
02/21/17 12:01 AM
crabman173
crabman173
In class where you want an A you answer get springs set up to near 050 from coil bind In the REAL world nothing could be farther from the way it usually happens Think about Dart for example--they sell thousands of heads with springs that will work well with a wide range of lifts up to a certain lift--so does Edelbrock etc So you are never at that magic number Take a set of heads to a REAL RACE shop and spend big $$--or have them build you a serious race only unit and..guess what? you get the springs ( usually high quality PAC or others) set up exactly on the edge of about 050 to 060 from coil bind Do that at home and get trouble--you FORGET to check the all important inner didn't you? and IT is the one that binds and friggs everything up--and you were aimin to impress by getting it " like the big boys do" right? Whew!! Big mistake for home builders!!!!! I have built hundreds an hundreds of race engines that had all kinds of room to coil bind--with a GOOD driver they win races and don't fail!! Valve springs usually fail for several plain boring reasons
#1 Tool steel they don't lose pressure--but...those darn things break! A failed spring is a tool steel spring--ever wonder why there are millions of sets of high dollar springs on Ebay cheap--they run them ONE race and toss them so they don't break #2 Interference--something is banging into something else--simple--you did not build it right and do not know what the heck you are doing #3 They floated because you rev'd them beyond the limits of the cam/lobe design/part used/ etc You again--screwed up and maybe don't know how to drive a RACE car #4 they did not have enough pressure to control your "dumb azz custom cam" that you should have had an engine builder spec out instead of the 4 week guy at COMP ( try Bullit or Jim at Racer Brown or Cam Motion and keep on winning) #5 valve train is HEAVY ( because it is a Mopar) and again you do not have enough spring to control that fat girlfriend of a cam lobe spec'd by a damn computer that has never raced anybody #6 you failed to use Titanium retainers--if you did not use them you do not know what you are doing--repeat this several times before you go to bed tonight Silicon springs do lose a little pressure but they never break unless you bang then into something else Me likey!!!
[Re: ]
#2256993
02/21/17 02:35 AM
02/21/17 02:35 AM
I set my heads up with the springs, retainers and keepers that will go on that valve one at a time. I have a older Rimac 1000 lb. valve spring tester that I use to set the springs up on,I do not set them all up to the same specs. I have hardened valve springs shims in .015, .030 and .060, I also measure all of them as I use them. I see around .004 t0 .006 variance in the shim thickness I use lightweight checking springs to check the piston to valve clearances, intake lobe timing as well as the lift at the retainers to verify the rocker arm ratio at the retainers. I see from .015 to .020 loss of lift with the race springs on the heads compared to the checking springs That ends up making them have from .070 to around .090 clearances on the springs from coil bind, I do that with the thought that the aluminum heads will get from .003 to .012 taller when warmed up racing it than the length of the steel valve stem will grow when hot Lots of variables out there for Murphy to use to mess with us racers and engine builders
[Re: Cab_Burge]
#2257001
02/21/17 03:15 AM
02/21/17 03:15 AM
Posts: 6,130 Melbourne , Australia
LA360
Basically anyone who built Comp Eliminator or Super Stock engines that I've dealt with usually runs their springs closer to bind than 0.040"-0.050" Many go to around 0.020" or there abouts
Alan Jones
[Re: hemienvy]
#2258643
02/24/17 12:26 PM
02/24/17 12:26 PM
Posts: 4,205 New York
polyspheric
And the way we know that every individual coil compresses at the same rate, at the same time, so they never touch and generate a shock wave is...?
Boffin Emeritus
