Help with power brake booster #999794
05/25/11 06:34 PM
05/25/11 06:34 PM
kauai
maxi333 Offline OP
maxi333  Offline OP
kauai
I am having the most trouble trying to find the correct booster it's driving me mad! I have a 68 Plymouth satellite that started life as a 318 all drum car.
sometime in the 80s it was converted to disc brakes up front utilizing 80 m body front calipers which i've laready replaced with 74 dart calipers. however the 80s m body power booster looks nothing like the booster that i need to replace. i've ordered several 68 satellite power drum boosters and power disc boosters which would all bolt to my master cylinder but the bolts on the back of the booster do not match up to the mount off the firewall... it's driving me mad.
the measurements from my old booster measure vertically from the outside of the bolts(that is how cardone measurements are) 3.8125" and horizontally from the outside of the bolt 4.0625" does anyone have a clue what i should order? also between my old master cylinder and booster there was a spacer of sorts that had some sponge like material attached to it which i cannot find either... help
i talked with cardone tech and it seems that the re-manufactured boosters are coming in with the wrong bolt dimensions but how could this happen this often?!?
any help would be great
1962 Chrysler 300 convertible 383/727
1970 Dodge A108 Boogie Van 318/727
Re: Help with power brake booster [Re: maxi333] #999795
05/25/11 06:42 PM
05/25/11 06:42 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Post a picture....
FWIW this would be a Midland Ross booster which is what should have come on a power drum brake car...
Re: Help with power brake booster [Re: maxi333] #999796
05/25/11 06:42 PM
05/25/11 06:42 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Check with BoosterDewey..
Re: Help with power brake booster [Re: 1_WILD_RT] #999797
05/25/11 06:45 PM
05/25/11 06:45 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
And this is a Bendix which would come on a disc brake car...
Re: Help with power brake booster [Re: 1_WILD_RT] #999798
05/25/11 07:08 PM
05/25/11 07:08 PM
kauai
maxi333 Offline OP
maxi333  Offline OP
kauai
Post a picture....
Yeah it looks just like that midland ross booster complete with the spacer unfortunately that's a bit outta my price range
i also forgot to mention that when i look up the booster on the part store websites and even when i go into the store the images they have look just like my old booster.
but the booster that comes in looks different.
Re: Help with power brake booster [Re: OzHemi] #999799
05/26/11 02:58 PM
05/26/11 02:58 PM
kauai
maxi333 Offline OP
maxi333  Offline OP
kauai
I checked my old booster and there are no numbers I'll try to get pictures this weekend...
I'm gonna try a couple more part numbers then i guess i'll have to use booster dewey and hope he'll have that spacer that goes between the booster and the master cylinder.
Re: Help with power brake booster [Re: maxi333] #999800
05/26/11 03:06 PM
05/26/11 03:06 PM
garnett kansas
rhad Offline
rhad  Offline
garnett kansas
why dont you send yours in and have it rebuilt????????
Re: Help with power brake booster [Re: rhad] #999801
05/26/11 03:23 PM
05/26/11 03:23 PM
kauai
maxi333 Offline OP
maxi333  Offline OP
kauai
unfortunately i'm on a tight budget and i was impatient to finish my brakes. I was just going to re-use it but then i noticed cracks in the rubber and i was missing the spacer that i remember taking off(my pops prob tossed it) I was finishing up my brake system that weekend.
so i order one from bumper to bumper auto to pickup and they accidentally order the disc brake version. thinking that may have been the issue i turned around and ordered the drum version from advanced auto that part too was wrong. frustrated i called up cardone and they said it may have been boxed wrong. so i ordered it again from bumper to bumper hoping to squash the brakes this weekend nope same deal looked different but most of all the back bolts did not line up it kinda just turned into a fiasco on me.
i should have just had booster dewey rebuild it from the get go and wait a week i have another power booster i'm going to try then hopefully booster dewey will have some of those spacers lying around lol what a mess
Re: Help with power brake booster [Re: maxi333] #999802
05/27/11 12:16 AM
05/27/11 12:16 AM
kauai
maxi333 Offline OP
maxi333  Offline OP
kauai
Good news folks! My last shot in the dark ended up being a bullseye, I ordered a 74 Dart booster just by chance and it's the correct one complete with the space I will install tomorrow! Thanks for all the help!
One last thing in the spacer I seem to remember there being some sponge material between the plastic piece and aluminum piece. Does anyone know if that material is required, because my new one didn't come with any... Maybe I need to cut my own? If so does anyone know what material it is?
Thanks again!
Re: Help with power brake booster [Re: maxi333] #999803
05/27/11 12:20 AM
05/27/11 12:20 AM
Under My Car
Mopar_Country Offline
Under My Car
I just replaced my MC a couple of weeks ago and the foam piece in mine was virtually non existent. I just cut and shaped a piece of foam and put it in there, not sure of it's purpose other than to keep dirt out. All is good.
Re: Help with power brake booster [Re: Mopar_Country] #999804
05/27/11 12:31 AM
05/27/11 12:31 AM
kauai
maxi333 Offline OP
maxi333  Offline OP
kauai
Sounds good I will do the same thanks
