what?! you're flat out wrong!!! if it came from the factory, it's good enough!!
oh.. wait...
I always loved those answers "Ma knows best" which seems to always pop up on cooling systems, whether it's asking about what stat to use, whether to drill it or not, or even to have one at all...to e-fans vs mechanical flex blades to clutch fans...radiator hose springs...coolant mixtures....
sure, stock worked great when the engine was...uh...stock. but all that kinda goes out the window when you're talking about an aluminum headed, high compression, stroker!
bottom line, the spring or no spring is just one more thing to check when you're having cooling problems. on a brand new hose, you probably don't need it. but 5 years from now when you start overheating on the highway...add a spring before you do anything else, including post a question here! if the spring works, then you know that you needed one. if the spring does not fix the problem, then you didn't need one!
