What flywheel for 71 383 3-speed manual ? #999563
05/25/11 10:13 AM
05/25/11 10:13 AM
Wisconsin
FFwithRT Offline OP
FFwithRT  Offline OP
Wisconsin
I need to order a flywheel for my 71 RR 3-speed manual trans car. Do I get a 130 tooth 6 bolt 10&1/2 or what will be correct? Thanks in advance, Greg ffgreg32@aol.com
Re: What flywheel for 71 383 3-speed manual ? [Re: FFwithRT] #999564
05/25/11 11:00 AM
05/25/11 11:00 AM
Ohio
Dan Brewer Offline
Dan Brewer  Offline
Ohio
Yes the 10.5" 6 bolt flywheel would be correct. Same bell/flywheel/clutch that a 4-speed car would use.
Dan
A833 4-speeds, parts & services
http://www.brewersperformance.com/
