Starter bolt and stud specs?? #999539
05/25/11 09:12 AM
05/25/11 09:12 AM
VA
AtomicDog Offline OP
VA
I'm about to install a starter in my '96 Dodge Ram 2500 4x4 and misplaced the OEM bolts during the engine swap. Does anyone know what length and thread size/pitch the top starter bolt is? Also, need to know what the thread pitch/size is for the fine threaded stud that is coming out of the transmission for the starter fastening nut. I suspect that these are SAE threaded fastners, but I'm not sure.
Re: Starter bolt and stud specs?? [Re: AtomicDog] #999540
05/25/11 09:20 AM
05/25/11 09:20 AM
moparx Offline
moparx  Offline
the top bolt is 7/16-14 pitch[can't remember the length, but is approximately 1 1/4 or 1 1/2 or so long]. the bottom stud is 7/16-20 pitch. hope this helps.
Re: Starter bolt and stud specs?? [Re: moparx] #999541
05/25/11 03:05 PM
05/25/11 03:05 PM
VA
VA
Thanks. That sounds about right - top bolt may be a bit longer than 1-1/2", but I can check that. I believe that they have used the same setup for the small/big block starter bolt/stud for the past 45 years (at least since the beginning of the Torqueflight transmission back in the mid '60's).
Re: Starter bolt and stud specs?? [Re: AtomicDog] #999542
05/25/11 07:52 PM
05/25/11 07:52 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The top of the starter takes a 7/16"-14 X 1 1/2" bolt.
The stud is 7/16" X 2", 14 threads on the case end and 20 on the nut end.
Re: Starter bolt and stud specs?? [Re: AtomicDog] #999543
05/25/11 09:53 PM
05/25/11 09:53 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
440 Source has a bolt and stud kit
Gus
64 Plymouth Savoy
Dana 60
Re: Starter bolt and stud specs?? [Re: fourgearsavoy] #999544
05/25/11 11:27 PM
05/25/11 11:27 PM
VA
VA
Thanks folks. I appreciate the info.
