Take off either batt cable. The old stuff you pull the shaft out to turn on the h lights then tape a penny to your thumb and press on the little rounded nub in the middle on the bottom side of the head light sw which will let you pull the knob/shaft all the way out then unscrew (CCW) the bezel nut to free the switch then seperate the black bakelite electrical connector on it w the wires then it's free. If yours is still like this. EDIT b 4 you pull it see if you have fire at/to the dimmer sw & if so work from there downstream toward the lights. There's (3) terminals on the dim sw (1) hot in from the h lite sw then the other 2 go to either the low or the high beams so w h light sw on, 2 terminals should b hot depending if you are on low or high beams.
