B Body wiring problems again #999271
05/24/11 06:15 PM
05/24/11 06:15 PM
Georgetown Ontario Canada
anlauto Offline OP
anlauto  Offline OP
OK
Back at the steering column...We fixed the yellow wire...
Which wire for the ignition should be constant power with the key in the run position?
The blue/tracer or the brown.
At the switch connection I have constant power with the key on, but at the firewall I have no power UNLESS I turn the key to the start postion and hold it, then the blue wire gets power at the bulkhead and the engine runs ONLY if I hold the key in the start position...
CHECK OUT MY NEW WEB SITE !
Re: B Body wiring problems again [Re: anlauto] #999272
05/24/11 06:25 PM
05/24/11 06:25 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
You need to tell the owner of the car to buy a shop manual . Isthe ballast resistor ok ? That is a sign of a bad ballast resistor.
Re: B Body wiring problems again [Re: JohnRR] #999273
05/24/11 06:30 PM
05/24/11 06:30 PM
anlauto Offline OP
anlauto  Offline OP
I have the shop manuals...The issues make no sense. I've had great help here in the past, that's why I return with these questions.
I checked the ballast resistor first, I now have it by-passed and it makes no difference....My problem is inside the car, before the power exits the car.
Re: B Body wiring problems again [Re: anlauto] #999274
05/24/11 08:40 PM
05/24/11 08:40 PM
blue/tracer. See if it's hot at the back of the ign switch if it's in the dash or at the dangling connector under the steering col if the ign sw is in the col then see if it's hot at the firewall half of the bulkhead. This is w the ign sw in run "ign1". If so continue downstream
Re: B Body wiring problems again [Re: JohnRR] #999275
05/24/11 09:10 PM
05/24/11 09:10 PM
anlauto Offline OP
anlauto  Offline OP
Thanks everybody...
