B Body wiring problems again
#999271
05/24/11 06:15 PM
05/24/11 06:15 PM
Posts: 11,854 Georgetown Ontario Canada
anlauto
OK
Back at the steering column...We fixed the yellow wire...
Which wire for the ignition should be constant power with the key in the run position? The blue/tracer or the brown. At the switch connection I have constant power with the key on, but at the firewall I have no power UNLESS I turn the key to the start postion and hold it, then the blue wire gets power at the bulkhead and the engine runs ONLY if I hold the key in the start position...
CHECK OUT MY NEW WEB SITE !
Re: B Body wiring problems again
[Re: anlauto]
#999274
05/24/11 08:40 PM
05/24/11 08:40 PM
RapidRobert
blue/tracer. See if it's hot at the back of the ign switch if it's in the dash or at the dangling connector under the steering col if the ign sw is in the col then see if it's hot at the firewall half of the bulkhead. This is w the ign sw in run "ign1". If so continue downstream
