Are 273 & 318 Heads the same? #999225
05/24/11 05:00 PM
05/24/11 05:00 PM
MA
ragtop Offline OP
ragtop  Offline OP
MA
Are 273 & 318 Heads the same? I am asking about 1968. Thanks.
Re: Are 273 & 318 Heads the same? [Re: ragtop] #999226
05/24/11 05:32 PM
05/24/11 05:32 PM
scratchnfotraction Offline
yes..more or less
Re: Are 273 & 318 Heads the same? [Re: ragtop] #999227
05/24/11 08:41 PM
05/24/11 08:41 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
68 used the exact same head on both, it was the first open chamber head for either.
Re: Are 273 & 318 Heads the same? [Re: scratchnfotraction] #999228
05/24/11 10:05 PM
05/24/11 10:05 PM
Desert Tracker
HYPER8oSoNic Offline
Desert Tracker
yes..more or less
"Stupidity is Ignorance on Steroids"
"Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
Re: Are 273 & 318 Heads the same? [Re: HYPER8oSoNic] #999229
05/24/11 10:36 PM
05/24/11 10:36 PM
Minnesota
peabodyracing Offline
Minnesota
It's been too many years but I believe the 273 heads came with adjustable rocker arms because they used solid lifters. The 318's would have hydraulic rocker arms. You can certainly switch the rocker assemblies if needed. I know guys used to seek out the 273 heads specifically because of the rockers. It seems like there were some subtle differences in exhaust port shapes, but nothing too serious.
Re: Are 273 & 318 Heads the same? [Re: peabodyracing] #999230
05/24/11 10:52 PM
05/24/11 10:52 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
You're correct on the rocker arms.
Careful, your character's showing!
Re: Are 273 & 318 Heads the same? [Re: mopar346] #999231
05/24/11 11:57 PM
05/24/11 11:57 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
68 273s had stamped rockers for use with the new for 68 hydraulic cammed 273. 1967 heads (920 castings)are the same on 273 and 318 but rockers are different (though interchangable if the whole valve train is switched). 66 and older 318 had poly heads and 273s had a head nearly identicle to the 67 head but with a slightly different intake bolt angle(315 casting head and at least one other casting number I can't remember). 68 through 84 318 and 273 heads are virtually all identicle with little more than casting number changes and smog ports on some of the later heads.
