Electrical question... Flaming River kill switch... #999030
05/24/11 01:57 PM
05/24/11 01:57 PM
Houston Texas
PAINT IT BLACK Offline OP
Got a CHIP on my shoulder
Houston Texas
I bought a Flaming River combination battery and alternator kill switch:
http://www.flamingriver.com/index.php/products/c0015/s0001/FR1013
Does anyone here have one of these installed on their ride?
I am devising a plan for the cleanest install and would like some input (location, bracket, etc). Also, the directions aren't very clear... I am taking it that I am to use this as a pit stop for all the mentioned terminals (+, coil, starter, etc)....?
Re: Electrical question... Flaming River kill switch... [Re: PAINT IT BLACK] #999031
05/24/11 03:55 PM
05/24/11 03:55 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Is your battery in the trunk or up front? If it's in the rear then fab up an L shaped bracket and hang it down low under the valance or bumper like what you would see on a typical drag race car. If it's not going to be raced you can mount the bracket so it's tucked up underneath the car a little more.
If your battery is still up front then that leaves you with mounting it near the battery someplace like the fender apron, the frame rail, or maybe down low on the radiator support. If you wanted to hide it you could mount it underneath the battery tray if you have room to get your hand in there to twist the knob.
Re: Electrical question... Flaming River kill switch... [Re: Neil] #999032
05/24/11 05:31 PM
05/24/11 05:31 PM
Houston Texas
Houston Texas
Its up front. I have my ECU mounted under the tray, so no go there. I was thinking of drilling a hole through my rad. support beneath the tray to mount it vertically, but I wanted to see if there were any better ideas out there before I took the plunge.
