2 pressure plates came with my project...which to use? #998977
05/24/11 11:11 AM
05/24/11 11:11 AM
Tenn.
jrwoodjoe Offline OP
Tenn.
I'm going to attempt to bolt the trans with the 340 engine today. I have 2 pressure plates that came with my project and not sure which I should use.
Pressure Plate #1) Is a rebuilt unit (I think raybestos) with 3 fingers and is fairly heavy.
Pressure Plate #2) Is an older brand that is supposed to be performance. It is a Ztreeter brand and has lots of cone shaped fins as opposed to the 3 fingers. It is lighter.
Which should I go with?
65 Barracuda
70 Challenger
Re: 2 pressure plates came with my project...which to use? [Re: jrwoodjoe] #998978
05/24/11 12:36 PM
05/24/11 12:36 PM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
The three finger one is probably a Borg & Beck type [ could be a Long type ] and was the type used by the factory. The one with many smaller fingers is a diaphragm type. The Borg & Beck will very likely make for a stiffer pedal and will require that you keep the pedal overcenter spring in place in order to keep the pedal effort reasonable. Borg & Beck type clutches tend to be very reliable which is why the factory used them. Diaphragm clutches give a lighter pedal feel and can work quite well IF they are well designed. Centerforce,McLeod, and Sachs all make good diaphragm clutches. I don't know anything about the Ztreeter clutch. Improperly designed diaphragm clutches lack holding power and tend to hang up at high rpm. Some people remove the overcenter spring when using a diaphragm clutch, but this isn't necessary if you install a positive stop on the clutch pedal to prevent overcentering. The choice is yours.
Re: 2 pressure plates came with my project...which to use? [Re: 5spdcuda] #998979
05/24/11 12:45 PM
05/24/11 12:45 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Ztreeter Clutches & Zoom Gears = Same Company
Re: 2 pressure plates came with my project...which to use? [Re: 1_WILD_RT] #998980
05/24/11 02:39 PM
05/24/11 02:39 PM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
I remember having a Zoom clutch in my '66 Street Hemi. Not very impressive, at least not in a good way. Maybe they're better now.
Re: 2 pressure plates came with my project...which to u [Re: 5spdcuda] #998981
05/24/11 05:51 PM
05/24/11 05:51 PM
Tenn.
Tenn.
Thanks for the input guys. The Zstreeter had been sitting on a shelf for 20 years and I couldn't recall the actual quality of them. After I read your posts, I went back and looked at the Zstreeter unit. The edges of the surface area were pretty rough and I could actually flick pieces of metal off with my finger nail. After looking at both units again, I went with the Raybestos one. It just looked better made overall.
Thanks again for the advice.
65 Barracuda
70 Challenger
Re: 2 pressure plates came with my project...which to u [Re: jrwoodjoe] #998982
05/25/11 02:45 AM
05/25/11 02:45 AM
Tucson, AZ
Ramrod39 Offline
My New Title
Ramrod39  Offline
My New Title
Tucson, AZ
Good choice. Over the years I installed two Zoom clutches in hod rods. Both failed in short order.
