2004 Dodge Stratus 2.7 L V6 ECU replacement #998750
05/23/11 10:24 PM
05/23/11 10:24 PM
Arizona
az426john Offline OP
Arizona
Can anyone recommend a good reliable company to buy a replacement ECU for a 2004 Dodge Stratus 2.7L V6, Automatic from?
Re: 2004 Dodge Stratus 2.7 L V6 ECU replacement [Re: az426john] #998751
05/23/11 11:59 PM
05/23/11 11:59 PM
illinois
rbkt65 Offline
rbkt65  Offline
illinois
why do you need computer?some other parts houses around here can get you one already programmed for you-the do it by using your Vin number.
Re: 2004 Dodge Stratus 2.7 L V6 ECU replacement [Re: az426john] #998752
05/24/11 12:20 AM
05/24/11 12:20 AM
D/FW
gts95 Offline
gts95  Offline
D/FW
Try the car-parts.com website. You should be able to find it there.
1970 Super Bee, WM21, 383, auto, FY1, a/c, project! 1971 Chrysler 300 2dr, U-code, console car 1980 Chrysler LeBaron LS Limited coupe 2008 Chrysler Aspen, HEMI 2011 Ram 3500 MegaCab, 6.7
Re: 2004 Dodge Stratus 2.7 L V6 ECU replacement [Re: rbkt65] #998753
05/24/11 11:24 AM
05/24/11 11:24 AM
Arizona
Arizona
Thank you for taking the time to reply.
My daughter’s car had an oil leak that basically fried some portion of the computer and now the check engine light will not go off.
When she goes to have the car emissioned here in Arizona it will fail regardless of the fact that everything else works. So we need to replace the computer before she goes to emissions.
Re: 2004 Dodge Stratus 2.7 L V6 ECU replacement [Re: az426john] #998754
05/24/11 08:18 PM
05/24/11 08:18 PM
illinois
rbkt65 Offline
rbkt65  Offline
illinois
have you even had codes read to find out what it was/seems to me that unless code will not erase or if some shop told you it needed computer-I think I would get 2nd opinion-computer will have to be identical # and car equipped same way your car is for it to work-see if you can get code/codes for more help
