What glue to use for a vinal top???? #998374
05/23/11 02:26 PM
05/23/11 02:26 PM
Escondido, CA. Ron Podsiadly,...
Mopar Ron Offline OP
we are getting ready to install a vinal top on my sons 70 coronet and wanted to know what glue we should use and if it can be bought in spray cans?
can the yellow contact cement for counter tops be sprayed out of a spray gun like spider webbing???
thanks in advance. Ron....
Re: What glue to use for a vinal top???? [Re: Mopar Ron] #998375
05/23/11 03:24 PM
05/23/11 03:24 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
auto body supply shops sell both liquid, and aerosol vinyl top adhesives. use one made for vinyl tops, if you want it to last.
http://www.legendaryautointeriors.com/files/VINYL%20TOP%20INSTALLATION%20GUIDE.pdf
Re: What glue to use for a vinal top???? [Re: Mopar Ron] #998376
05/23/11 10:10 PM
05/23/11 10:10 PM
Indiana, Just Off I-70
BradD Offline
BradD  Offline
This is what I hear from many of the Pro's:
"Dap (Weldwood) spray grade Landau Top adhesive. Do not be tempted to use anything from a rattle can."
It is for high temperature (as in a roof) use. Shipping is expensive because it is considered hazardous. They recommend finding a local top shop.
Brad
Check out the Dorn's 69 Barracuda "Switchblade" in the Nov.2010 MCG
Check out the Dorn's refurbished 36 Ford in the Feb.2011 Street Rodder
Re: What glue to use for a vinal top???? [Re: BradD] #998377
05/23/11 10:43 PM
05/23/11 10:43 PM
Shelby, Ohio
2
2abodymcodes Offline
Shelby, Ohio
3m super trim adhesive. part # 08090. i have used this to install new vinyl tops years ago that still look good. comes in a large spray can. takes 4 to 5 cans to do an average top. if you follow the instructions, it will not come loose.
Re: What glue to use for a vinal top???? [Re: BradD] #998378
05/23/11 11:35 PM
05/23/11 11:35 PM
Brandon, Ms
cornet684me Offline
cornet684me  Offline
Brandon, Ms
i bought a gallon of DAP, used all but a little, worked great
Re: What glue to use for a vinal top???? [Re: Golden-Arm] #998379
05/24/11 01:08 AM
05/24/11 01:08 AM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
Thanks for the link! I saved it to my computer!
Re: What glue to use for a vinal top???? [Re: 2abodymcodes] #998380
05/24/11 08:13 AM
05/24/11 08:13 AM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
put on two vinyl tops with this stuff and it worked great. The one on my Duster has been on for 7 years now.
Re: What glue to use for a vinal top???? [Re: dustergirl340] #998381
05/24/11 10:47 AM
05/24/11 10:47 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
X100%...been using it for close to 30 years installing vinyl tops, or any interior applications needing a good long lasting adhesive, on my cars or customers, never had a problem other than a can clogging,...so buy extra, you can always return the unused stuff, better than getting caught short during an application,....the only time I see people have a problem with the 3M spray is due to inexperience...
Mike
Re: What glue to use for a vinal top???? [Re: DAYCLONA] #998382
05/24/11 11:32 AM
05/24/11 11:32 AM
Thanks everyone, I remember using the 3M super trim adhesive when I did my wifes challenger around 02 and it worked great
when I did the padded cover on my Squattie truck I had issues with it not holding around the edges but I am not sure if it was 3M adhesive I used, I bought it from the place I bought thew vinal from,
I'll make sure we get the 3M stuff
Thanks again for all the info Ron...
Re: What glue to use for a vinal top???? [Re: DAYCLONA] #998383
05/24/11 11:38 PM
05/24/11 11:38 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
Mike
yet another. One other tip: Ask your supplier if you can return unused cans. If they allow it, get an extra or two. Murphy says one will clog on you. Mine went on with no problem and the parts place took the unused cans back. I know that if I did not have those insurance cans, it would not have gone as smoothly. My Cuda only needed three cans. I also had three helpers to unfold the vinyl going on.
Craig
Re: What glue to use for a vinal top???? [Re: Mopar Ron] #998384
05/25/11 02:40 AM
05/25/11 02:40 AM
Missouri
MOBodyman Offline
MOBodyman  Offline
Missouri
Years ago I used to occasionally help a top installer. He swore by Formica Brand countertop cement and he sprayed it out of an old cheap siphon feed gun. He never cleaned the gun either, just run a little thinner thru it. You couldn't pull the tops loose either.
I've also used the 3M Super Duty aerosol without any problems.
Dallas
2012 Rallye Redline Challenger, 1st new car!
2010 Ram 1500 4wd HEMI-hauler
2014 Dodge Dart-gas saver
4 projects and a bunch of parts cars, losing interest since buying the Challenger lol
1969 Dodge Coronet 500-'gonna fix 'er up someday!'
Re: What glue to use for a vinal top???? [Re: BradD] #998385
05/25/11 07:37 AM
05/25/11 07:37 AM
detroit,michigan
ctsuperbee Offline
ctsuperbee  Offline
detroit,michigan
yes please use the weldwood landau top adhesive. it comes in a liquid. i bought a cheap 15.00 paint spray gun from harbor freight. figuring i could throw it out after using it. it worked great. i,ve never installed one previously, but i always got compliments at car shows how nice the top looked. dont use anything out of a spray can. it will lift and bubble and ruin your top.
