Any pictures of a Key Cylinder for 71 charger? #998113
05/23/11 12:32 AM
05/23/11 12:32 AM
BigAg Offline OP
BigAg  Offline OP
Ever since I have had my 71 charger the Key Cylinder would come out if you pulled on it. I took a deeper look at this problem today and think maybe the cylinder i have might be for a different model. The little spring loaded lock retainer seems to be in a different place on the cylinder then it should be. Am thinking i may need to buy a correct one but want to verify first.
Re: Any pictures of a Key Cylinder for 71 charger? [Re: BigAg] #998114
05/23/11 08:06 AM
05/23/11 08:06 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
1970 - 1971's have a circular spring loaded clip.( see pic )
1972 and later have a pin that holds them in.
I don't know for sure but have my doubts they will interchange
Re: Any pictures of a Key Cylinder for 71 charger? [Re: gtx6970] #998115
05/23/11 10:49 AM
05/23/11 10:49 AM
BigAg Offline OP
BigAg  Offline OP
that is exactly what the problem is. The guy that had the car before me put a 72 in instead of a 71. Looks like I will have to locate one for a 71. Any chance of anybody carrying one cheaper then year one?
Re: Any pictures of a Key Cylinder for 71 charger? [Re: BigAg] #998116
05/23/11 11:52 AM
05/23/11 11:52 AM
Montreal,Quebec,Canada
JulesdaWiperman Offline
super gas
super gas
Re: Any pictures of a Key Cylinder for 71 charger? [Re: JulesdaWiperman] #998117
05/23/11 10:23 PM
05/23/11 10:23 PM
SF Bay Area, CA
charger440sixpak Offline
SF Bay Area, CA
http://cgi.ebay.com/ebaymotors/NOS-Door-...sQ5fAccessories
Got a full set of locks from Tom for my 71 R/T and the ignition lock fits perfectly.
