2000 Stratus fuel pressure regulator location? #997436
05/22/11 12:40 PM
05/22/11 12:40 PM
dusterguy Offline OP
My Stratus is bleeding down fuel pressure. I checked it with a gauge and assume that the pressure regulator is bad. I traced the fuel lines front to back and also checked the rails--no luck in finding it. Please help.
Re: 2000 Stratus fuel pressure regulator location? [Re: dusterguy] #997437
05/22/11 12:47 PM
05/22/11 12:47 PM
illinois
rbkt65 Offline
rbkt65  Offline
illinois
in tank on pump-be careful if you buy Airtex from big box parts houses-try to buy Bosch/?? lifetime
Re: 2000 Stratus fuel pressure regulator location? [Re: rbkt65] #997438
06/09/11 07:22 PM
06/09/11 07:22 PM
You were right. This was the 3rd defective Airtex pump that I installed. I insisted on a Bosch pump and all of my problems went away. This was my local mom and pop parts house.
By the way, I am getting good at changing fuel pumps!!!!!
