installing rear window in my Duster "?". #996773
05/21/11 05:26 PM
05/21/11 05:26 PM
Elk Grove, Calif.
bigblock340power Offline OP
Elk Grove, Calif.
What do you use in the channel that the glass sits in, in the glass rubber? Is their some kind of adhesive or sealer? I'm thinking their is but I can't remember what it is.
A little help please.
Re: installing rear window in my Duster "?". [Re: bigblock340power] #996774
05/21/11 09:41 PM
05/21/11 09:41 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I just did this in the FrankenDuster.....
NO sealant. I used wd-40 to act as a lube though.....
Re: installing rear window in my Duster "?". [Re: Kern Dog] #996775
05/23/11 06:06 PM
05/23/11 06:06 PM
edmonton , alberta , canada
squeek360 Offline
squeek360  Offline
On this topic ish... how successfull would attempting to remove the rear window and save it for reinstallation be? my car has to go back to the painter and I've got nearly every window out except the rear...the front I was replacing so I didn't care if it cracked on the way out.. the rear though, yikes I don't wanna kill it
thanx in advance and sorry for the thread tangent
Re: installing rear window in my Duster "?". [Re: squeek360] #996776
05/23/11 09:17 PM
05/23/11 09:17 PM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
The rear on my 74 Duster had a locking strip in the black gasket. I'm not sure if all Duster/Demon/Dart Sport cars had the same design from 70-76. I have pulled several rear windows out. I always cut the gasket apart and pulled the glass out that way. When I recently replaced the rear window in my FrankenDuster, I was careful to NOT damage the rubber seal. This was my first rear window install. ZERO leaks too.
Re: installing rear window in my Duster "?". [Re: Kern Dog] #996777
05/24/11 05:44 PM
05/24/11 05:44 PM
Elk Grove, Calif.
Elk Grove, Calif.
I have a new rubber seal to work with. I was recommended this to put in the out and in side channels of the seal, prior to installing the window.
Re: installing rear window in my Duster "?". [Re: bigblock340power] #996778
05/25/11 12:51 AM
05/25/11 12:51 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
I would think that if the manufacturer suggests it, they may have a point. I have only installed ONE rear window. I used no sealant and it doesn't leak. Maybe I got lucky.
