Re: Race Fuel in a street car [Re: wally426ci] #996271
05/25/11 05:34 PM
05/25/11 05:34 PM
Maryville tn
67coronetman Offline
Maryville tn
I run about 3-5 gals in my 12 gal fuel cell.! Works great for me.
Old car are me......
Re: Race Fuel in a street car [Re: 67coronetman] #996272
05/25/11 07:16 PM
05/25/11 07:16 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Seemed to dry out my rubber lines very quickly & the dye in the fuel would tint the rear of the car
Re: Race Fuel in a street car [Re: ademon] #996273
05/25/11 09:33 PM
05/25/11 09:33 PM
owensboro, ky
rallye73 Offline
rallye73  Offline
owensboro, ky
110 worked great in my SRT-4, but it's got a high octane mode built into the ecm. It's got mopar stage 3 upgrade. High octane is good for 50hp on it vs. pump gas. Sorry guys...little off topic. I know we're not talking late models.
Re: Race Fuel in a street car [Re: ademon] #996274
05/25/11 10:06 PM
05/25/11 10:06 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
If it's "tint" the back of your car, then the tuneup is off.
I have to disagree...
To the contrary actually.
I have been selling at my business and using race fuel since 1984.
I used to run straight race gas in my street cars for many years, like 15.
Myself and freinds have run it straight in our 2 stroke dirts bikes, straight in jet skis, chain saws, weed eaters and many different gensets straight. So I swear to you too much octane and lead ain't gonna hurt any kind of engine(non computer). Sure it might hurt your wallet, but not your engine.
You don't want to run leaded fuel in a engine that uses O2 sensors, we sell a 100 or 104 octane unleaded for those engines.
Now the great thing about race gas, is that it has stabilizers and other additives that help for it to last a long time, drasticly different than pump gas, exspecially ethanol gas.
The reason I speak up is because it's wonderful stuff to store your car with. I store gensets with it and they ALWAYS start.
I parked my 360 74 challenger in my garage running in 1987 with straight 110 Turbo Blue which is a leaded race gas. I started that car about every 6 months or so, sometimes longer other times shorter until 2003. I swear, The car never moved or left the garage, I remember adding Turbo blue in 5 gal jugs during that time. It never failed to start.
Today I drive that car a lot with the same fuel tank, same edlebrock carb, same fuel pump, same stock original steel fuel lines.
That gas helps things like your fuel pump last and my rubber fuel lines have never suffered. Rubber hoses, carbs, valves, pistons all LOVE lead and racing gas has lead, just like the good old days.
So that's my take on it fron 25 years of selling and using leaded race gas.
Some guys didn't like smelling my dirt bike in the woods behind me, I told them then try to get in front of me? Eventually they would be running it and keeping up!
Seriously after a few years when prices starting climbing we cut back to 50/50 mix in our sport machines and muscle cars.
And I have run many gallons of ethanol gas from the pump while we are out of town with the car driving it in extreme conditions, all with the same fuel system that was subject to 100% race gas for over 15 years.
Drove it to the top of Pikes Peak 2 years ago, it made it to the top with no problem with unleaded 92 gas in the tank.
Re: Race Fuel in a street car [Re: Challenger 1] #996275
05/26/11 09:27 AM
05/26/11 09:27 AM
San Jose, California
DennisH Offline
Vacation
DennisH  Offline
Vacation
91 Octane $hit gas here in California. 440. 9:5:1. No ping. Runs good.
Re: Race Fuel in a street car [Re: wally426ci] #996276
05/26/11 12:19 PM
05/26/11 12:19 PM
Arizona
az426john Offline
az426john  Offline
Arizona
As for fuel in a race car. Be sure to read your spark plugs at regular intervals as well as your oil level. Aviation fuel is a "slow burn" formula designed to burn with less oxygen at the upper altitudes. It also has a blue dye in it which can cause havoc with idle jets being that the dye can leave a white powdery substance that can restrict an orifice size. Aviation fuel is also a cleaner fuel and tends to strip oil (and sludge) from metal so checking the oil level should be mandatory. Lastly, several small bore engines run fine with it, while others may not. Large bore engines are up for grabs. Each is an individual case. Aviation fuel does not work well in my Chevy V8, or my Harley's. It does work well in the street sweeper, high pressure washer, forklift, etc. etc. I see a lot of formula racers using it. Fuel injected engines/racers generally have to retune to use it.
Re: Race Fuel in a street car [Re: az426john] #996277
05/26/11 12:25 PM
05/26/11 12:25 PM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
Try some in your lawn mower
