Re: EZ-EFI on my 440 [Re: Viol8r] #995767
05/20/11 10:47 AM
05/20/11 10:47 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Put some drive time on it while watching the computer and hold a steady speed at each rpm, and it will "learn" the map. Once its close, if it still cogs a little, go into the set-up and increase the squirter shot till it accels real good...
Re: EZ-EFI on my 440 [Re: Viol8r] #995768
05/20/11 07:49 PM
05/20/11 07:49 PM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
I had the same clearance issues on my Charger with the XFI setup. I also utilized the Spectre plenum but modified it quite extensively to fit under the hood, over the fuel rails and around the throttle linkage. Here's some pictures of the before and after.
Re: EZ-EFI on my 440 [Re: PC-CHARGER] #995769
05/20/11 07:50 PM
05/20/11 07:50 PM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
after fabrication and painting
Re: EZ-EFI on my 440 [Re: PC-CHARGER] #995770
05/20/11 07:50 PM
05/20/11 07:50 PM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
Installed
Re: EZ-EFI on my 440 [Re: PC-CHARGER] #995771
05/20/11 08:15 PM
05/20/11 08:15 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Rick
Looks GREAT!
Re: EZ-EFI on my 440 [Re: Mopar_Rich] #995772
05/20/11 08:18 PM
05/20/11 08:18 PM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
Thanks Rich. Now just gotta figure out where to put 8 coil packs and a bunch more wire!!!
Re: EZ-EFI on my 440 [Re: PC-CHARGER] #995773
05/20/11 08:56 PM
05/20/11 08:56 PM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
Installed
my old boss was the one who did your carbon fiber coating.
Re: EZ-EFI on my 440 [Re: chrisf] #995774
05/20/11 08:58 PM
05/20/11 08:58 PM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
That would be Trevor, correct?
Re: EZ-EFI on my 440 [Re: PC-CHARGER] #995775
05/21/11 12:31 AM
05/21/11 12:31 AM
Dalton, MA
Slipknot440 Offline
Slipknot440  Offline
Dalton, MA
I wish mine worked . The guy installing it has had it for 3 weeks. The car starts perfectly but once put into a Reverse or Drive it dies. I think he posted about it on here earlier this week.
Re: EZ-EFI on my 440 [Re: Slipknot440] #995776
05/21/11 01:37 AM
05/21/11 01:37 AM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
Check your timing, specifically the mechanical advance. The EZ-EFI does not control timing and with some of the light advance springs installed in performance engines, the weights are on the verge of opening at idle. The EZ computer sets the idle speed in neutral but the advance weights have advanced the timing a bit so the idle speed is up. As soon as you drop it in gear the motor lugs down a bit, the weights drop in and timing retards and the idle drops to a point where it stalls. This happens with carbs as well but with the EZ-EFI it is very touchy. Get the distributor recurved so that there is no advance before around 200-300 RPM above your idle speed in neutral.
Re: EZ-EFI on my 440 [Re: PC-CHARGER] #995777
05/21/11 05:43 PM
05/21/11 05:43 PM
Woodinville, WA
Viol8r Offline OP
Viol8r  Offline OP
Woodinville, WA
Installed
Very nice custom plenum. I have the same Spectre plenum on the car now and made it work.
I do not see any heater hoses?
Re: EZ-EFI on my 440 [Re: PC-CHARGER] #995778
05/21/11 07:55 PM
05/21/11 07:55 PM
Rome, GA
GTXX Offline
GTXX  Offline
Rome, GA
Using one of the lightweight springs and the lightest of the stock springs has worked well for me to fix this problem.
Re: EZ-EFI on my 440 [Re: Viol8r] #995779
05/22/11 01:25 AM
05/22/11 01:25 AM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
Haven't decided if I want to put the hoses on or not yet. Heater box is in place with a new heater core but still undecided. I like what you've done for heater hoses so maybe I'll try something like that.
Re: EZ-EFI on my 440 [Re: Viol8r] #995780
05/22/11 09:54 AM
05/22/11 09:54 AM
Coram, NY
Pool Fixer Offline
Pool Fixer  Offline
Coram, NY
it looks great.did you have any clearance issues with the hood?what kind air cleaner are you using?
Yes, the hood clearance takes some thought. You can't use a normal drop base air cleaner as it hits the fuel rails. So we ordered a Spectre aluminum plenum box and it only takes up 2" of space. Has (2) 4" inlets on each side with 4" tubes. I currently can't get the tubes to fit so we are just going to run the plentum box with fine pre-filter foam covering the openings. I will post pics on that soon and it should work fine.
Someday when I get some time the solution maybe using oval tubing to get the hood clearance.
This is in a '68 Charger with an RPM intake, so results may very with different combos......bottom line is can't use drop bases with the EZ-EFI.
I ran a TB years ago (projection) and it was shorter than the eddy carb that it replaced.
just thinkin out loud if your TB was shorter than a carb like mine was and you ran a holley street dominator, maybe a 68 unsilenced or other round filter would fit under a stock hood
