Re: Warped trans steels, what caused this ????? PICS
[Re: 340Scamp]
#995554
05/19/11 12:46 PM
05/19/11 12:46 PM
Posts: 74,974 U.S.S.A.
JohnRR
U.S.S.A.
Slipping clutch, the clutches don't look bad??? The clutches not holding caused those steels to warp like that. Clutches are GARBAGE , use the Hi energy clutches as a replacement if you haven't already bought the rebuild kit.
edit ... looking at the picture I see the rear clutch stack in the back ground , that's the front clutch , this was probably caused by the front drum having the inner piston seal cut too deep , there is a wider replacement seal to remedy this , it comes in the seal kit , if it doesn't specifically get one and use it.
[Re: 340Scamp]
#995561
05/19/11 07:10 PM
05/19/11 07:10 PM
JohnRR
U.S.S.A.
I bought the truck with the trans already bad. I think I found the problem. The output shaft is seized at the sprag. Took tailshaft off and the output shaft will not move by hand. Had to put channel locks on it to turn it and still is extremely tight. Also can't get the rear drum off, band is loose but drum won't come off.
The lube circuit is plugged up the rear support is lubed by the fluid that runs into it from the rear line, when that clogs that is what happens . There is a modified rear support made by Sonnax that has modified lube paths for the mainshaft and the drum, you are going to have to force the thing apart and replace the mainshaft, the support and the rear drum.
Sonnax has 2 supports, one upgrade part # 22754N-01K and one with a larger OOD on the surface that the drum rides on so you and bore out the ID of the drum because they are expensive to replace, part # 22754N-02K
[Re: JohnRR]
#995562
05/19/11 09:36 PM
05/19/11 09:36 PM
Posts: 125 kalispell montana
jwilson 61
kalispell montana
you had better repair the check ball in the trans line up by the radiator or you will tear up the support again as the lube circuit to the support and intermediate shaft gets cut off by a stuck check ball in the line also check for good cooler flow..better yet remove the check ball and put a full time lube kit in the valve body
70 cuda 440 6bbl Auto with a dana 60 68 road runner QQ1 383 auto 1970 6 barrel 4 speed Superbird FY1 number matching 15 Challenger 6.4 SRT pearl White 6 Speed 72 Cuda 440 5 speed 71 Road Runner 440 4 speed
[Re: jwilson 61]
#995564
05/20/11 12:16 PM
05/20/11 12:16 PM
JohnRR
U.S.S.A.
Good point , if the converter wasn't the source of the trash that clogged the cooler circuit it's possible that the rubber line with the check ball failed .
[Re: 340Scamp]
#995566
05/20/11 09:17 PM
05/20/11 09:17 PM
jwilson 61
kalispell montana
usually found right where the lines turn from steel to rubber before the radiator cooler its part of the connector right at the steel line. it disconnects right there and you can see the check ball inside the connector. the full time lube really helps vehicles with remote starters keep from burning up front pump bushings and associated parts
[Re: 340Scamp]
#995570
05/21/11 03:39 PM
05/21/11 03:39 PM
Posts: 25,747 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Where in the line is the check ball located? I traced the lines from the trans to the radiator and can't seem to find it. Also what does it look like?
Below is a pic of the check valve line; top is factory original, bottom is replacement.
The factory installed the check valve to prevent the cooler from draining back into the transmission through the converter. In older days the cooler was mounted in the bottom radiator tank near the level of the transmission but the newer crossflow radiators with side tanks place the cooler above the level of the transmission.
Removing the check valve might require placing the shifter in Neutral for the first start of the day.
[Re: Supercuda]
#995572
05/22/11 02:45 AM
05/22/11 02:45 AM
JohnRR
U.S.S.A.
Hmm, this may explain my wife's 05 Ram's trans. Take it a bit to get going when you put it in gear. Bet the check valve is stuck open letting the converter drain back. So, where does one get the "good" check valve?
Probably not the check ball sticking , later rams seems to have the drainback issue as delivered from the factory , tell her to start it , pop it into neutral and wait a minute , should be all set to go .
[Re: JohnRR]
#995573
05/22/11 11:17 AM
05/22/11 11:17 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
This problem is fairly new to the vehicle, we've owned it since new.
[Re: Supercuda]
#995574
05/22/11 11:22 AM
05/22/11 11:22 AM
JohnRR
U.S.S.A.
Not sure what line or where the check ball is on that year , follow the lines till you find the rubber line in the picture above , that has the check ball in it .
[Re: Supercuda]
#995575
05/22/11 07:37 PM
05/22/11 07:37 PM
John_Kunkel
Rio Linda, CA
Although the factory calls it a converter check valve it's actually a radiator cooler drainback valve, nothing can prevent the converter from draining back...with or without the check valve.
The popular opinion is that there is no "good" check valve, they're all prone to clogging with debris from the converter clutch and causing the damage in the OP. Best to replace the check valve hose with a regular hose with no valve and make the first start of the day in Neutral to refill the converter.
Better yet, install a filter in the cooler feed line.
[Re: John_Kunkel]
#995576
05/23/11 07:41 PM
05/23/11 07:41 PM
Supercuda
About to go away
About to go away
up yours
So. I go to my favorite online parts store, RockAuto, and I cannot find this hose listed. Anyone got any suggestions for a check vale free hose, or at least the threads at these fittings so I can install a good filter?
