?? cam change for using pump gas?? #994852
05/18/11 12:20 PM
05/18/11 12:20 PM
michigan woods
imfixinmopars426 Offline OP
michigan woods
.030 383 dome trw's,stage VI heads,.528 MP solid. we cant use 93-92 oct,knocks bad @ 37 deg,mostly street car....sooooo anyone know of a cam,near the lift of 520-530 to bleed off compression,so we can run pump gas 93??? i really hate to change pistons,ect. sorry dont have a cranking compression right now. any help would be great,,,thanks,mike
Re: ?? cam change for using pump gas?? [Re: imfixinmopars426] #994853
05/18/11 04:11 PM
05/18/11 04:11 PM
Not what you requested but might consider retarding the cam 4 deg & exp w stiffer dist spring
Re: ?? cam change for using pump gas?? [Re: RapidRobert] #994854
05/18/11 06:09 PM
05/18/11 06:09 PM
southern California
1970sixpak Offline
1970sixpak  Offline
southern California
I would look at running a thicker head gasket.
