Adjusting b-body doors #994650
05/18/11 12:37 AM
05/18/11 12:37 AM
Brandon, Ms
cornet684me Offline OP
Brandon, Ms
how do you adjust you doors? my door on my 68 dodge coronet is sticking out a little, it needs to come in some so it does not stick out further out than the body
Re: Adjusting b-body doors [Re: cornet684me] #994651
05/18/11 12:48 AM
05/18/11 12:48 AM
Lakewood, Colorado
herkamer Offline
herkamer  Offline
Lakewood, Colorado
Looks like you need to pivot the door in on the bottom hinge, on the door side and not on the pillar side. May have to loosen the top a little so that it will come in. Probably will have to adjust the fender bottom once that is lined up, because it will bring that in as well.
Matt
69 Dart Swinger 340
83 W350, Megasquirted with 46RH
Old news: 72 Demon street/race mobile
Latest: 70 Duster backhalf car
and even more
Re: Adjusting b-body doors [Re: herkamer] #994652
05/18/11 01:09 AM
05/18/11 01:09 AM
Brandon, Ms
Brandon, Ms
so all the adjustments are made with the hinges? how do you make adjustments with the hinges?
Re: Adjusting b-body doors [Re: cornet684me] #994653
05/18/11 02:16 AM
05/18/11 02:16 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
You have some slop when the bolts are loose and you adjust the slop to get a good body line. Loosen, adjust, snug, check, repeat if necessary. Tim
