Springs for Comp Cams XE274H
#994350
05/17/11 06:03 PM
05/17/11 06:03 PM
Posts: 3,719 Space Station #5
471Magnum
Space Station #5
Getting ready to install a Comp Cams XE274H in my small block 410 stroker. Currently my plan is to run my 2.02 valved J-heads on the motor. Comp Cams recommends their 995 spring for use with this cam, but these are double springs requiring machining to the head. Something I want to avoid. Furthermore, the 995 springs would require new retainers as well.
I’m contemplating running the 901 single spring with damper instead. It’s a 99% street car and I don’t intend to rev the snot out of the thing, so my gut feeling is that I should be okay.
These heads are a budgetary compromise. Really want to run a set of prepped- RHS heads, but I’m a few bonus checks away from being able to do that. Bottom line is that I don’t want to put any more money into these J-heads than necessary.
The lift on the cam “only” 491/480. I purposely selected it over the higher lift, but similar duration XE275HL for that reason.
Any suggestions?
-Jim
I can fix it... my old man is a television repairman. He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: Springs for Comp Cams XE274H
[Re: 471Magnum]
#994351
05/17/11 06:25 PM
05/17/11 06:25 PM
Posts: 27,453 So Cal
autoxcuda
So Cal
I don't have an answer for that. But I run the spring that came with my Edelbrock head with my very similar 274-S cam. Just a solid version of what you have.
I happy with that cam. Nice street compromise. More torque than I can put down on the street even with a single plane intake.
BTW you're title says 274HL- high lift cam. Might confuse people.
[Re: Baxter61]
#994353
05/17/11 06:56 PM
05/17/11 06:56 PM
471Magnum
Space Station #5
Sorry about the typo. Fixed it.
Yes. It's the XE274H
-Jim
[Re: 471Magnum]
#994354
05/17/11 10:23 PM
05/17/11 10:23 PM
Posts: 4,799 ILL
MLR426
ILL
Yes. It's the XE274L
Don't you mean H for hydraulic ? If thats the case the 274 calls for around 300 open load, which is important with this aggressive cam profile.
logan426 Martin Performance Plus Cylinder Head Odin,IL
