E 85 fuel and TQ's: Can it be done? #994002
05/16/11 11:54 PM
05/16/11 11:54 PM
Desert Tracker
HYPER8oSoNic Offline OP
Desert Tracker
Can the TQ be set up to run E85? Or, is the composite body incompatible with the E85 fuel? I had thought about a corrision resistant center body/fuel bowl assembly. Basically, would the TQ meter the E85 fuel as well as it does the gasoline?
"Stupidity is Ignorance on Steroids"
"Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
Re: E 85 fuel and TQ's: Can it be done? [Re: HYPER8oSoNic] #994003
05/17/11 12:31 AM
05/17/11 12:31 AM
Franklin CT
syleng1 Offline
syleng1  Offline
Franklin CT
My TQ is holding up to the crap we have here in CT for fuel. So far it is dealing with the alcohol pretty good. I'm not sure of the e-85 but i do know that the body of the carb is probably not the problem, its the aluminum that is the issue.
Joe
Re: E 85 fuel and TQ's: Can it be done? [Re: HYPER8oSoNic] #994004
05/17/11 12:33 AM
05/17/11 12:33 AM
Florida STAYcation
dIc dOc Deity ! Offline
The village idiot's idiot
Florida STAYcation
Me thimks that some guy from MINIsota did this ...
Re: E 85 fuel and TQ's: Can it be done? [Re: dIc dOc Deity !] #994005
05/17/11 01:00 AM
05/17/11 01:00 AM
Desert Tracker
Desert Tracker
Mr. Fiberglass, what is your op in all this? (From a TQ perspective, of course!)
Re: E 85 fuel and TQ's: Can it be done? [Re: syleng1] #994006
05/17/11 01:05 AM
05/17/11 01:05 AM
Desert Tracker
Desert Tracker
Joe
I would figure the aluminum would be the "achilles
heel" in the system. So, the the top and base, hmm? Any solutions for it,other than a "blended" version of E85?
Re: E 85 fuel and TQ's: Can it be done? [Re: HYPER8oSoNic] #994007
05/17/11 01:05 AM
05/17/11 01:05 AM
Florida STAYcation
Florida STAYcation
The MORE I think of this .. the more I like it. BIG compression ....snappy and crisp sound ...good power.
Re: E 85 fuel and TQ's: Can it be done? [Re: dIc dOc Deity !] #994008
05/17/11 01:39 AM
05/17/11 01:39 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I ran e-85 in my thermo-quad in Tennesse for years with no problems in my 68 cuda, original fuel tank and lines included.
Re: E 85 fuel and TQ's: Can it be done? [Re: HYPER8oSoNic] #994009
05/17/11 07:09 AM
05/17/11 07:09 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
Worked great. Dave
http://www.moparts.org/moparts/picture/print/pages/Vraa.html
Re: E 85 fuel and TQ's: Can it be done? [Re: quickd100] #994010
05/17/11 09:37 PM
05/17/11 09:37 PM
Desert Tracker
Desert Tracker
Worked great. Dave
Thanks for the link. How high of compression do you use vs. the absolute limit on both iron and aluminum heads?
Re: E 85 fuel and TQ's: Can it be done? [Re: HYPER8oSoNic] #994011
05/18/11 07:28 AM
05/18/11 07:28 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
I was at 11.26-1 and wished I'd been at 12.5-13-1. DTHemi on the board runs it at 15-1 in his 654 Hemi. Dave
