Thermoquad stumble at throttle tip-in, need help. #99383
08/04/08 01:24 AM
08/04/08 01:24 AM
Manitoba, Canada
DaytonaTurbo Offline OP
Manitoba, Canada
Having a problem with the thermoquad lately. At throttle tip-in the motor will stumble for a second or so before responding. This happens at both part-throttle acceleration and at snaps to full throttle, but it is much more noticeable at snaps to WOT. I can't think of what's happening. I haven't made any changes recently. I checked and the choke is opening all the way, so I know it's not that. It does it at part throttle as well as full, so it has to be something to do with the primaries.
Anyone have a suggestion as to where to look??
Re: Thermoquad stumble at throttle tip-in, need help. [Re: DaytonaTurbo] #99384
08/04/08 01:41 AM
08/04/08 01:41 AM
near Harrisburg, Pa
440trk Offline
440trk  Offline
near Harrisburg, Pa
I'd look at your accelerator pump setting first.
If that checks out OK...I'd consider enlarging the squirter.
Re: Thermoquad stumble at throttle tip-in, need help. [Re: DaytonaTurbo] #99385
08/04/08 01:45 AM
08/04/08 01:45 AM
see if there is an accel pump squirt as soon as you crack the throttle & any obvious vac leaks.
